c32 rear diff locked up! What to do?
Old Jul 20, 2008 | 06:27 PM
abergstrom81's Avatar
So I was messin around in a parking lot last night doing a brake stand, everything seemed fine when I parked it at home. When I woke up today and pulled out the rear tires were binding! Has anyone heard of this or had it happen to them? Any help or advise would be appreciated.
Old Jul 20, 2008 | 06:35 PM
evilsaint's Avatar
'02 C32, '10 135i M-Sport, '10 E63, '17 GLE63S
Don't mean to insult your intelligence or anything, but have you checked to make sure your parking brake isn't stuck? I guess it probably wouldn't be the case if you drove home after the "fun"...
Old Jul 20, 2008 | 07:17 PM
It feels like I have a welded diff. It's fine when driving straight but when turning the tires bind.
Old Jul 20, 2008 | 08:30 PM
greasybenz's Avatar
W203 C32 AMG, W124 E300D
Sounds like the parking brake to me, especially if the car will go foward with ease but wont reverse. You may have damaged the parking brake internals youll have to pull out to drivers side rear brake rotor and check.
Same thing happen to me on my 300SD.
Old Jul 20, 2008 | 10:49 PM
OLDSCHOOLRICE's Avatar
07' E350, 71' DATSUN 510
I would say that you probably seized up the bushing in the differential.
I doubt it's the parking brake because you can still spin the tires, which is what the parking brake stops the tires from doing. However a welded/locked differential causes the tires to bind or chirp during a turn due to the fact that while turning the outside wheel spins more that the inside wheel.
There's a post I read a long time ago about a slk32 doing a lot of drifting with a stock diff and he ended up seizing up the bushing on the pin for the sun gears in the diff. One of the wheels was spinning a lot more than the other causing the bushing that the pin rides in to heat up excessively and sieze.
Just look at it as your car asking you to install a quaife!!
Old Jul 21, 2008 | 08:15 AM
mkonei's Avatar
05 C55
thats backwards. the tires will chirp while turning if theyare not allowed to turn at different speeds. thats why spools are not recommended for street use. time to take it apart...
Old Jul 21, 2008 | 03:33 PM
Sorry, I should have said that the outside wheel "wants" to spin more than the insde wheel but can't due to the differential being locked or seized.
Old Jul 21, 2008 | 07:31 PM
Eleventeen's Avatar
2002 C32 AMG
Yes. I doubt it has anything to do with the parking brake. I did too many donuts and damaged the pin that holds the spider gears in place.
Mercedes wanted $2400 to replace with factory rebuilt unit, but my warranty co. said they would only cover $1400 at one of their recommended shops 1.5 hours away. I ended up purchasing a used diff and doing it myself for $850. My warranty co. reimbursed me.
Old Jul 22, 2008 | 08:17 PM
I'm probly gonna end up installing myself...anyone know where I could find a used rear differential?
Old Jul 22, 2008 | 09:49 PM
Zeppelin's Avatar
C32
Just install the Quaife LSD instead of putting the stock diff back in.
Old Jul 23, 2008 | 04:17 AM
more151please's Avatar
2007 E550, 2011 BMW 335i
hell buy mine and i will put a qualife on... that will be most likely my next upgrade or headers
Old Jul 23, 2008 | 05:20 PM
Eleventeen's Avatar
2002 C32 AMG
Here's were I got mine; I would definitely buy from them again.
http://www.socalmercedesparts.com/about-us/
