--- LET C32 Intake Almost Ready ---
#201
It shouldn’t be too much of an issue. They’re more inclined to scrutinize for missing carburetor pre-heat devices on antiquated machines, imho.
My smog technician forgot to notice its heat exchanger, high flow exhaust manifolds, SL55 splitter, and ODPS during its most recent inspection. Perhaps he remembers the Mrs.’ freshly baked cookies and preferred distilled beverage given at Christmastime each year.
That, and the fact it runs pretty cleanly:
If the visual portion of the test could still present a problem, it'll be a simple task to swap the OE setup back in come test time. With the glut of unused C32 airboxes soon to be available, I suspect their value on the resale market will be drastically diminished. I’ll be keeping mine for just those reasons.
![](http://i209.photobucket.com/albums/bb196/splintersAMG/C32SmogCheck4.jpg)
#204
2008 A8L, 2002 996TT X50, 2009 X5
Although, if it really bothers anyone - keep in mind, you could probably "mod" the LET intake with whatever universal 3" filter you'd prefer instead
I do wonder if the HKS 2-ply wet filter is any different from their new 3-ply dry filter, performance-wise... anyone know?
#205
+1, agree w/ loungn14
IMHO, the gains/results should be roughly identical - so why bother? But that might just be me...
#206
In talking with LET, the hotter air from the engine bay would be a minimal issue at low speed (e.g. stop and go traffic), but pretty quickly you're getting more than enough cooler air through the grill, which is where the filters are pulling their air from.
#207
Probably wouldn't have enough airflow, due to insufficient filter surface area - just a guess on my part, though.
#208
The intake imo will work great...the C32 suffers from heat soak regardless and unless you have a chiller tank or nitrous(going thru the TB) it will heatup eventually even with an upgraded H-E...but it won't be the intakes fault....where the filters are as long as the hot engine air is being forced back(which higher speed does) the hot engine air should not affect it at all or much imo... I personally like this intake idea...![thumbs](https://mbworld.org/forums/images/smilies/thumbsup.gif)
#209
![](http://itgfilters.net/images/11976733504911176299425.jpeg)
#211
#215
#218
One thing I noticed, in looking more closely at Jerry's and Newzchspy's pics of the intake - the metal panel welded to the tubes, which aesthetically cleans up the look of the intake (especially when the stock engine cover is used) - doesn't seem to necessarily always line up quite right. It got me thinking - could the inside edge of those plates have tabs extending downward, so that the intake hooks into the same holes the stock airbox clips to? That way you'd always have a consistent alignment... anyway, just a thought
#219
#222
05 c55, 08 600rr
as a c55 owner, i feel like the neglected middle child. the older brother has all these achievements, has made himself into a much better person since being born. the younger brother has his whole life in front of him, is the shiny new kid everyone wants to be around, talks of great things to come, talks about the potential he has...
c55 owners...poor poor middle child. came out strong, oooooo v8. but soon was over shadowed by 63. and the older brother 32 graduates to the big leagues.....
anything for us n/a folks?!?!?
#223
#224
One thing I noticed, in looking more closely at Jerry's and Newzchspy's pics of the intake - the metal panel welded to the tubes, which aesthetically cleans up the look of the intake (especially when the stock engine cover is used) - doesn't seem to necessarily always line up quite right. It got me thinking - could the inside edge of those plates have tabs extending downward, so that the intake hooks into the same holes the stock airbox clips to? That way you'd always have a consistent alignment... anyway, just a thought ![thumbs](https://mbworld.org/forums/images/smilies/thumbsup.gif)
Yes, it does have tabs and yes, they work'
#225
I think you misunderstood... if you look at this picture:
https://mbworld.org/forums/attachmen...5&d=1220541061
I'm simply pointing out that the black plates aren't parallel with your intake plenums. IMHO, it would look more 'polished' if they were.
One way for LET to rectify this in their design would be adding metal tabs extending downward from the inside edges (i.e. plenum side) of the plates, hooking into the same oval slots that the factory airboxes clip into. This would ensure a parallel alignment with the plenums, and would be a very minor design change to implement - perhaps something for LET to consider on a subsequent production run, if they deem appropriate.
Personally, if the plate isn't aligned with the plenum (and consequently, the front cover), I'd say just leave it off. The whole purpose is to improve the looks - if it's crooked, it doesn't achieve that IMHO... if anything it detracts from it.
That said, the alignment from Jerry's pics appears to be pretty much perfect, so maybe this was just on your set, since you had a one-off with smaller tubing...? In the end, it was just an idea I had, which I felt like offering - it certainly won't hurt my feelings if no one else feels the same way... the important thing is that the intake works, and from the initial feedback, it sounds like it works well
