C32 Intercooler Pump Issue
Old Aug 16, 2008 | 12:00 AM
fuwing's Avatar
C32
hi guys i am new here. just got my 02 C32 (RHD) and seems like the IC pump is failling coz it is lossing power at 150km/h. does anyone have the parts code of the OEM IC pump? and the relay? i am aslo interested in getting the Johnson CM30 pump but it is very hard for me to get it here in Hong Kong. i went checking (http://www.pumpagents.com/JohnsonPumps/10-24504-03.html )about the Johnson pump and found that there are 2 models, anyone has the the idea about which one is the correct one? and is there anywhere else i can get it? sorry about all these questions. thanks guys and wish you all have a nice weekend!
Old Aug 16, 2008 | 02:50 AM
CLKCLK's Avatar
03 C32 gone, 06 CLS55, 16 Tesla X
LET has it for a lot cheaper $175. If I am not wrong, it had been sold for $125 shipped before.
Old Aug 16, 2008 | 02:54 AM
c32used's Avatar
LET C32 2002
+1
Old Aug 16, 2008 | 03:12 AM
fuwing's Avatar
C32
i did send them a email but havent heard from them yet. not sure if they will ship oversea.
that's why i want to know the codes for the factory IC pump and relay....
Old Aug 16, 2008 | 08:58 AM
c32used's Avatar
LET C32 2002
Keep trying cause like C3P they are quite busy also.
Old Aug 16, 2008 | 08:59 AM
loungn14's Avatar
SPONSOR
From: Houston/ Austin /Toronto / UAE / Minneapolis / Orlando /Cincinnati
Eurocharged Performance ML63 and TT lambo
Ya, also send AMG-Jerry a pm and he will get on it. Johnson just recently raised their pricing for all of their distributors so its now 175
Old Aug 16, 2008 | 02:12 PM
bobby02c32AMG's Avatar
2002 C32 AMG
+1 for LET Johnson Pump, I am pretty sure they will ship to you. This pump flows much better than the stock pump, and should also last a lot longer than the stock one. Also, I dont know if you are into mods or are going be adding mods in the future, but while you are installing your new pump you should think about installing a larger Heat Exchanger(LET, Code3) since it will be right there in front of you anyway. Its fairly inexpensive IMHO, and will help your car a lot with heat soak issues and keep your car running cooler. The stock heat exchanger is a joke compared to LET's or Code3's as it is SO much bigger. I just had a johnson pump installed with LET's HE and I can feel the difference big time, specially coming from a failing IC pump that would begin to stop pumping in third-gear at WOT.
So if I were you, I would for sure go with the Johnson pump and definitely think about a larger HE
Let us know if it was your pump, and how it drives after a fix.
Old Aug 16, 2008 | 03:24 PM
RedBull's Avatar
CLK550
IC pump failing? That's a new one.
Old Aug 16, 2008 | 09:37 PM
2002 C32 AMG
Sarcastic I hope right?
Old Aug 17, 2008 | 12:45 AM
RedBull's Avatar
CLK550
absolutely
Old Aug 17, 2008 | 01:26 AM
2002 C32 AMG
absolutely
Haha, good! I was kind of being sarcastic with my question too, considering all your other posts I have read lol!
Old Aug 17, 2008 | 06:18 AM
cnchung's Avatar
C32
I bought mine from HK as a replacement of the stock IC pump, if you want the contact of the dealer here, PM me.
Be expected that they need to order it as they don't keep stock as I know, mine took about 3 days to arrive. Installation is about an hour or two, minor fabrications needed.
Before that, pls also make sure that it is the problem of the IC pump.
Old Aug 17, 2008 | 08:52 AM
Newzchspy's Avatar
PLAID
[QUOTE=RedBull;3001489]IC pump failing? That's a new one.[/QUOTE]
Old Aug 17, 2008 | 06:45 PM
c32 dan's Avatar
c32 amg
pump issue
im sure LET ships to hk,ordered my pump and sparkplugs from them and its going to be shipped to the uk
Old Aug 17, 2008 | 10:28 PM
fuwing's Avatar
C32
thanks alot for all your comments. will wait for LET to get back to me and see.
Old Aug 17, 2008 | 10:30 PM
fuwing's Avatar
C32
will consider that HE too. just want to make sure they ship first.. thx
Old Aug 17, 2008 | 10:31 PM
fuwing's Avatar
C32
thx man. i will check out the Johnson pump first. would you mind to tell me what brand it was for your pump?
Old Aug 18, 2008 | 01:27 AM
fuwing's Avatar
C32
jsut wondering. anyone got the parts code for the factory IC pump and its relay? i want it jsut in case...thanks everyone!
Old Aug 18, 2008 | 07:35 AM
cnchung's Avatar
C32
Mine is a Johnson CM30.
