low output
Old Aug 20, 2008 | 03:24 PM
czwhat's Avatar
2003 C32 AMG
low output
I keep getting low output out of my car. I will be at a light or going up a hill and want to accelerate but cant. Sound like the supercharger doesn't kick in but it doesn't do it all the time plus I can still hear the intercooler pump when I turn the key off. Any ideas on what this might be?
Old Aug 20, 2008 | 03:58 PM
c32used's Avatar
LET C32 2002
Question
Any mods done to it?
Old Aug 20, 2008 | 04:24 PM
loungn14's Avatar
SPONSOR
From: Houston/ Austin /Toronto / UAE / Minneapolis / Orlando /Cincinnati
Eurocharged Performance ML63 and TT lambo
I would guess its the IC pump starting to fail. Thats what happened with mine. Off then on for a while. Completely random.
Old Aug 20, 2008 | 04:26 PM
c32used's Avatar
LET C32 2002
This is the best guess to all.
Old Aug 20, 2008 | 04:28 PM
czwhat's Avatar
2003 C32 AMG
I have code 3 pulley & Intake with let tune.
Old Aug 20, 2008 | 04:30 PM
c32used's Avatar
LET C32 2002
I would upgrade the i/c pump first cause it could be failing then see. If after new pump installed still same issue then post.
Old Aug 20, 2008 | 05:05 PM
c32AMG-DTM's Avatar
2008 A8L, 2002 996TT X50, 2009 X5
+1... upgrade the HE while you're at it.
Old Aug 20, 2008 | 05:13 PM
Eleventeen's Avatar
2002 C32 AMG
Since you already have mods, I would upgrade to the Johnson CM30. If this doesn't fix the problem, then you haven't wasted any money because this is a performance mod that you will benifit from as soon as the real issue is found. If it does fix the issue; there's your two dead birds, and it only cost you one stone.
