LET 185mm pulley question
Old Aug 22, 2008 | 09:36 PM
kindafast's Avatar
W210 E55 & W204 C63
LET 185mm pulley
Well I finally got my pulley, too bad my car is broken now
Can someone confirm that there are a total of three pulleys in LET 185mm pulley kit - Crank, medium light pulley, and small heavier pulley. Anyone know what the second and third pulleys supposed to replace? and where they are located?
Old Aug 22, 2008 | 09:47 PM
kindafast's Avatar
W210 E55 & W204 C63
Here is a diagram, just tell me which number the medium and smaller pulleys are going to replace please.
I think the smallest out of the kit is the waterpump and medium pulley seems like it could be a cover and not a pulley.
Attached Thumbnails LET 185mm pulley question-112k-engine.jpg   LET 185mm pulley question-pulleys-002.jpg
Old Aug 22, 2008 | 09:56 PM
430's Avatar
430
SLK32
That is correct. The LET pulley kit comes with a crank pulley, an ideler pulley, and the water pump pulley.
kindafast's Avatar
W210 E55 & W204 C63
Hmm strage I just measured my "185"mm pulley and it appears to be a 181mm. Could someone who already has a 185 please chime in, or measure theirs? It would really help me out!
I used a metric 30cm ruller to measure the pulley I just got from Eric and it appears to be 18.1 centimeters in diameter, which is 181mm. I alligned the ruler perfectly across, so that the diameter would be measured flawlessly, did it several times, same measurement - 18.1cm. Buttom line is there is no way to measure this pulley I have to be 185mm.
Attached Thumbnails LET 185mm pulley question-pulley-007.jpg   LET 185mm pulley question-pulley-008.jpg
Old Aug 22, 2008 | 10:32 PM
loungn14's Avatar
SPONSOR
From: Houston/ Austin /Toronto / UAE / Minneapolis / Orlando /Cincinnati
Eurocharged Performance ML63 and TT lambo
The middle pully in your picture is your water pump pully. It has the 4 bolt holes.
The smaller one is your idler pully.
Old Aug 22, 2008 | 11:38 PM
boohooramblers's Avatar
Not an AMG :(
It must be just a mix-up. That's definitely a 181mm.
Old Aug 22, 2008 | 11:57 PM
1qikctr's Avatar
Merc power
From the close up pics, 181 here too.
Old Aug 24, 2008 | 02:11 PM
c32used's Avatar
LET C32 2002
I say call Erick or Jerry and let them know incase the wrong pulley was sent due to them being busy mistakes can happen but let them know first before people start to get the wrong impression.
Old Aug 24, 2008 | 02:17 PM
amgstyle's Avatar
2002 SLK 32 AMG
when you say ideler pulley, can tell me which number pulley in it is in the picture above that was posted. thanks
Old Aug 24, 2008 | 02:50 PM
c32AMG-DTM's Avatar
2008 A8L, 2002 996TT X50, 2009 X5
the idler pulley is the small pulley with "LET Motorsports" engraved on it. It's 'guide pulley' #4 in the picture above.
You can see it pretty clearly in the 5th picture of my thread from awhile ago:
https://mbworld.org/forums/showthrea...685&highlight=
Hope that helps
Old Aug 24, 2008 | 03:22 PM
kindafast's Avatar
W210 E55 & W204 C63
They know don't worry, I talked to Eric, it appears to be that the manufacturer made the wrong size
Old Aug 24, 2008 | 04:46 PM
c32used's Avatar
LET C32 2002
Thumbs up
Glad it was resolved Glad you found it ontime before installing it...
