C55 BLACK SERIES, NEED HELP!!!!!!!
Hey everyone, I have a 2006 C55 and am going to be ordering the CLK BLACK SERIES 4 wheel brake setup. (buying all 4 rotors, calipers, pads, and sensors for all 4 wheels) Is there anything else that i am missing that i need to order to be able to have the it installed properly?
There was a post a while back where someone had already did this upgrade and wrote about it, but when i did a search, i could not find the link to the old post. Could you guys please help me find the post.
The reason it's soo important is i need to double check the part numbers AND I think there is a pair of brackets that are needed for the front calipers or something. They said in their old post that they just had to cut some of the dust cover off the back wheels and that was it, in order to install the CLK BLACK SERIES brakes on their C55. But I CANT REMEMBER if they included a part number for something like a bracket, to allow the front calipers to sit higher and clear the larger black series front rotors. PLEASE HELP!!!
Something Slow
CLK63 030 AMG BRAKES KIT
003-420-67-83 (Caliper) Front
003-420-68-83 (Caliper) Front
004-420-50-20 (Brake Shoe)
209-421-01-12 (Brake Disc) x2
003-420-29-83 (Caliper) Rear
003-420-30-83 (Caliper) Rear
004-420-49-20 (Brake Pad)
171-423-02-12 (Brake Disc) x2
![slap](https://mbworld.org/forums/images/smilies/slap.gif)
![off topic](https://mbworld.org/forums/images/smilies/ot.gif)
![crazy](https://mbworld.org/forums/images/smilies/crazy.gif)
So again thank you all who wrote with the intentions of helping me in this project. But as a side note, I want to order the BLACK SERIES clk63 brake kit, not just use the stock clk 63 brakes. Any ideas? ~thank you
![bow](https://mbworld.org/forums/images/smilies/bowdown.gif)
Oh, my bad...
because it's more important to you than anybody else's...
![smash](https://mbworld.org/forums/images/smilies/smashfreak.gif)
![](https://mbworld.org/forums/images/ranks/veteran_army.png)
Thank you all who wrote helpful answers, and to the
I am told the standard CLK63 brakes are:
360 x 32 mm with 6-piston fixed caliper-FRONT
330 x 26 mm with 4-piston fixed caliper- REAR
the CLK63BS are:
360 x 36 mm with 6-piston ????? caliper-FRONT
330 x 26 mm with 4-piston ????? caliper- REAR
But if someone knows for sure if the BS brakes are floating or FIXED, please comment.
the CLK63BS are:
E63 P30, CL500 Sport
the CLK63BS are:
the CLK63BS are:
