Anyone just using Code3 pulley, LET ECU and K&N setup?
Old Sep 8, 2008 | 05:44 PM
trbo2nr's Avatar
2004 C32, 2006 Honda CBR1000RR, 2007 Harley NightRod, 2013 Harley Road Glide Custom
Question Anyone just using Code3 pulley, LET ECU and K&N setup?
What's your mpg city/hwy. Thanks.
Old Sep 8, 2008 | 05:49 PM
Newzchspy's Avatar
PLAID
I was (now have the Code III and LET Intakes together). I saw as high as 25 MPG highway and about averages 19-20 city; Don't even ask about track days??
Old Sep 8, 2008 | 05:56 PM
trbo2nr's Avatar
I can't get above 23. Even hwy is 22.x I think I noticed this after adding the code3 intake- that's why I wondered if an earlier post with getting too much air could cause this? I will remove the code3 intake and see what happens. I am sure after I did the sc pulley, I was getting 27 mpg on the hwy.
Old Sep 8, 2008 | 06:35 PM
ScottW911's Avatar
Super Moderator Alumni
a C32 AMG & S-Works Tarmac
Please correct me if I'm wrong.
More air needs more fuel to create more power. Right?
If you are traveling at 70+ mph, you are probably running right at or above the S/C clutch threshhold (it kicks in at 2900rpm or 40% load, whichever is first). This means you are running the S/C and sucking more air/fuel tooling down the highway.
By the way, my stock C32 has gotten over 23 mpg once.
Old Sep 8, 2008 | 07:02 PM
trbo2nr's Avatar
That adds up. I just haven't messed with the fuel. On another car (turbo) I own, I ended up doing complete ECU, fuel injectors, intake etc. I just thought
I could get away with not yet needed the extra fuel- always some project to
work- aside from the house honey do list.
Time to look at the fuel and search the forum.
Old Sep 9, 2008 | 08:23 AM
Newzchspy's Avatar
PLAID
Have a tune? You could be running lean like I was, till Jerry got a hold of it!!
Old Sep 9, 2008 | 08:25 AM
Newzchspy's Avatar
PLAID
Even prior to the Code intake and LET tune, I routinely got 23-25 on Highway and once saw 26. I did this by staying OUT of the SC (which is hard to do). If you can run about 68 MPH, you should see 25 easily.
Old Sep 9, 2008 | 09:34 AM
c32AMG-DTM's Avatar
2008 A8L, 2002 996TT X50, 2009 X5
Question
Well... in your sig., you mention having an LET tune. In your post you mention "haven't messed with the fuel" - which is it?
ECU tuning primarily addresses spark timing advance and fuel maps (among other things) - so if you have a modded ECU tune, you most definitely have 'messed' with the fuel.
Old Sep 9, 2008 | 09:42 AM
_tomek_'s Avatar
e46 330d ++
sorry for the noob question but is the sc clutch programmable? Is it possible to change it to (f.e.) 3500rpm or 40%?
Old Sep 9, 2008 | 11:35 AM
ScottW911's Avatar
Yeah, right!
Keep it at 68....Glenn, you comedian!
Old Sep 9, 2008 | 11:36 AM
ScottW911's Avatar
To the best of my knowledge, no.
I would defer to someone like Vadim @ VRP for the truest answer though.
Old Sep 9, 2008 | 12:36 PM
c32used's Avatar
LET C32 2002
Pretty sure someone here is running same or similar setup.
Old Sep 9, 2008 | 03:27 PM
Newzchspy's Avatar
PLAID
Yeah, right!
Scott, Just because you have my brothers initials in your avatar doesn't mean I can't make jokes about 68.......................................SW!!! Remember, all numbers I post are in warp speed!!!
Old Sep 9, 2008 | 03:29 PM
Newzchspy's Avatar
PLAID
Jerry told me that it IS somehow. How, I didn't ask. In addition, there is also the possibility of having a switch to totally turn off or disengage the SC. I really like that thought BUt do not know how it would affect longevity of the SC or the engine (sucking air??) I 've heard of someone in GA running a SC on/off switch getting about 30 MPG on theirs??
Old Sep 9, 2008 | 03:47 PM
ScottW911's Avatar
There is a free and easy way to do this. The problem is that you need to open your hood to disengage/engage the S/C. Jerry showed me where the control plug for the S/C was when I felt that my S/C clutch was acting up. By unpluging the wires leading into the electomagnetic clutch, you too, can have a wildly expensive C320, that performs more like a lawn tractor. I did not have the patience to find out what the mpg would be.
By the way, I don't know what you were thinking , I was referring to being able to keep the speed down to 68.
Old Sep 9, 2008 | 04:14 PM
Newzchspy's Avatar
PLAID
I know you were, all my numbers are in Warp speed as in 68 is 6.8. OK Picard???
Old Sep 9, 2008 | 07:14 PM
trbo2nr's Avatar
Just LET modified ECU with my current setuo.
