Meth/Water/Alcohol Injection kit?
none
The reason that I didn't do a simple hobbs switch is that there would be no linear climb in spray. It would simply be 100% on and 100% off. I need this for more than WOT cooling. Also, in my application it is a magnacharger making only 4.5-5lbs of boost right out of idle. On a turbo that makes 20lbs of boost in a linear fashion the boost switch works perfectly. Using a boost switch for mine wouldn't do as well as the boost is pretty much on or off. No lag. Using the MAF volts you can set up the spray for a much more linear climb rather than "on" and "off".
none
Here is a link to the system I just finished installing. Thought you might like an example
https://mbworld.org/forums/c36-amg-c43-amg-w202/262025-meth-h20-installed-running-great-pics.html
just thought I would add something to this old post...
From http://www.snowperformance.net/faqs_...?type=gasoline
6. Where can I mount the nozzle?
Pre- or Post- throttle body/carburetor?
• Performance: It makes almost no difference. Before or after the throttle plate(s) won’t change the effectiveness of the fluid. A given amount of fluid will absorb a given amount of heat, whether it is done more before or after the throttle plate really doesn’t matter.
• Installation: It is usually easier to inject pre-throttle body in the intake tube. Easy access, no solenoid required (unless rear-mounting a reservoir). On a carburetor, it can actually be easier to use the #40050 carb spacer plate and a #40060 solenoid for a bolt-in installation. These components are included in our RT and MC series systems.
• In a blow-through carburetor setup with an air-box enclosure around the entire carburetor, injecting after the carburetor is preferable.
Pre- or Post- Supercharger/Turbocharger?
• Centrifugal/Turbo: (Procharger, Vortech, Paxton, Powerdyne, Rotrex, etc.) Never mount an injector nozzle before a centrifugal supercharger or turbocharger compressor. Sending fluid through the compressor wheel that spins anywhere from 50,000rpm to 250,000rpm can erode the leading edges of the fine aluminum, as well as serve to reduce the atomization. Instead of a fine mist, the compressor housing will create a river of fluid along the outside wall that means we get less benefit and use more fluid.
• Positive Displacement Supercharger: Roots style (B&M, Eaton, Magnuson, etc.) or twin screw (Lysholm, Kenne Bell, Whipple, etc.) Mounting the nozzle before this style of blower is perfectly safe and actually provides some additional benefits. The small amount of water-methanol fluid isn’t harmful to any rotor seals or surfaces or coatings, and it helps to seal the clearances and condense the air some more, resulting in a more efficient output. Additionally, it keeps the rotors and housing MUCH cooler, which reduces heat transfer to the rest of the intake and air charge.
Finally getting one of these installed this week, I will update and give my impressions after its in.
www.alcoholinjectionsystems.com
Hey Bobby:
I have warned others on this issue before, and I will gladly do it again.
Our blowers, being a Lysholm screw type, sorry for the spelling, operates on only a few thousandth's clearance. As you may know it is clearanced for AIR only. This is VERY important, as fluids CANNOT be compressed. If your system is spraying before the supercharger you are GREATLY risking it doing what is referred to as a "Hydrolock"
Thanks for the spell check below.
Please feel free to contact ANY positive displacement blower manufacturer and they will inform you that they set up the clearance for a EITHER a dry or wet system. AKA there is ALOT more clearance for a WET style, aka dragsters. I looked into this a while back for my Stang, as it had a Kenne Bell Whipple, aka Lysholm screw, and they informed me " Under NO circumstances do you want to run ANY liquid through the supercharger" Do what you like, but I would NEVER risk it my friend.
See yeah![drive](https://mbworld.org/forums/images/smilies/driving.gif)
PS: There is at least one guy on the W211 section that is running it, but again I defer you to the above physics/facts.
![EEK!](https://mbworld.org/forums/images/smilies/eek.gif)
See yeah
We've actually sprayed lots of Lysholm superchargers as well Kenne Bells on Mustangs (spraying the water methanol through the throttle body into the supercharger) without any issues. You won't hydro lock the supercharger. You guys will be fine spraying through the supercharger.
If anyone has any questions about water methanol injection feel free to post them here or Pm me directly.
Rodney
#32
Former Vendor of MBWorld
C55,SL55,C63
A member informed us of the thread and asked us to comment on it.
Rodney
Rodney
The problem I have as mentioned in another thread. Methanol is found an Automotive cleaners, Like brake parts cleaner. The AMG throttle body housing has a plate built that covers the rear supercharger rotor bearings. However its not a water or air tight fit. The potential for getting the bearing wet with water and methanol is real. If that happens it will ruin the bearings. The methonal will strip the grease out of them and the water combined with the methanol couse cause them to corrode. Resulting in a bearing failure, rendering the whole supercharger.. junk.
Another thing is.. One of the rotors is hollow. wouldn't you be afraid that fluid could build up inside the rotor?
Being a guy who has experienced a supercharger bearing failure. I'm worried about anything other than some air and recirculating crank case oil passing by my supercharger.
#33
For example the Chevy Cobalt with its Eaton M62 supercharger. Water methanol injection is extremely common on these engines. Were just one of about 5 other companies who sell systems for this application.
Look at the many Magnacharged, Kenne Bells and Whipple supercharged Corvette's. Literally hundreds of guys running water methanol injection on these engines. They just about have to since these are high compression (11:1) engines in which guys want more power and are installing aftermarket superchargers like the Magnachargers, Whipples, Kenne Bell's etc. Water methanol injection has become a staple item for the Corvette community.
Same goes for the Mustangs, Trailblazers, chargers etc. These guys have been running their engines now for years with out any damage to the bearing. If this was happening we would have an epedimic of damaged superchargers out there and people all over the internet complaining about this. Additionally, we would know about it as well and if that was the case we wouldn't continue to sell them to these type of supercharger owners.
One of the things you have to remember as well is how quickly this fluid flashes off. Especially pure methanol. It literally flashes off instantly when it meets the heat with in the supercharger. No chance of this fluid sitting around and collecting anywhere. Especially not inside of a hollow rotor. Just not going to happen.
Hope this helps explain thing better. Let me know if you have any other questions or feel free to express your thoughts on any of this.
Rodney
#34
I hear what your saying and its a perfectly understandable and reasonable concern. However, I can tell you that we have literally hundreds of customers running various twin screws or roots style superchargers running water methanol injection or pure methanol injection with no problems. Just step outside of your Mercedes community and look at the many other vehicles running it with no problems.
Rodney
Rodney
#35
Rodney
Rodney
Note, I went to the KB website to see what they say and "[Water Injection? It works, but the orifice, pressure, solenoid etc. must be calibrated (tuned) to the particular application. "
Again, I have had years of supercharging, as early as 1985 with a B/M, and EVERY manufacturer that I have ever talked to stated exactly what I printed above. Many had even offered me to set up their blower with a larger clearance to allow me to spray them. If they were not concerned, why would they off to do this?
Can you do it, sure. Will they stand behind their warranty in the event of a failure?This would be the question that I would ask to anyone comtemplating the use of an water/meth system
I am not trying to be the end all advise/reasoning here. I am just informing what many manufacturers have stated to me.
#36
Since I have not owned my KB whipplecharger for years now, and haven't followed up with KB for said reason. Does KB now recommend this![nix](https://mbworld.org/forums/images/smilies/nixweiss.gif)
Hope this helps.
Rodney
#37
A lots changed in the past two years. Its becoming quite common to run water methanol injection pre-compressor on turbo's or centrifugal. We literally set up at least one system a day with pre-compressor injection. having set up somewhere over 500-600 systems in the past two years. We have not had one problem with a customers compressor. I assure you at the rate in which we are setting up systems. If there was an issue we would have an epidemic of damaged impellers and pictures all over the net of this.
Hope this helps.
Rodney
Hope this helps.
Rodney
First off, I am not interested in a set up as I no longer own a C32. Secondly, don't you feel that as a vendor/seller, that you might be just a little biased
I believe it works, I have seen it work, and I fully understand the physics behind them that allows them to work.
However there are numerous owners of AMG's now that do not have an open pocket book. With that being said, what is your guarantee to those that are interested?
Please do not come back with that "we have thousands of users and not one has failed crap".
I am simply trying to give some experience/knowledge that I have learned over the years form several manufacturer's. Yes things always do move forward, and thank God for that. However physics are still physics. I don't know of any new gas laws written by Boyle lately, or for that matter ANY new physic laws.
So I will ask the million dollar question for the sake of those interested, "What is your guarantee on a system?"
#38
Hey Rodney:
First off, I am not interested in a set up as I no longer own a C32. Secondly, don't you feel that as a vendor/seller, that you might be just a little biased![nix](https://mbworld.org/forums/images/smilies/nixweiss.gif)
Rodney
#39
Just an example, as I believe you that MANY KB's have NEVER failed, magnachargers, etc, etc. I picked this example as I was NOT aware that the rear bearing are exposed up until recently.
#40
Hey Rodney:
By the way. I'm not promoting our system or talking about why your should buy ours over a competitors. I'm merely responding to the discussion of pre-compressor injection.
If you don't want to to believe we have hundreds of systems out there running it this way. Both gasoline and most of our turbo diesel trucks, then OK I nderstand..its the truth though. Just giving you a simple explanation. I've run precompressor injection as far back as 15 years ago when I ran a carburetted draw through turbo set up on a BBC. Dumped the entire fuel system right through the turbo. Worked great. No problems to the impeller. Lots of other guys did the same.
Look at the Anderson Mr Freeze water methanol kit. That things been around for 15 years. I know they have sold thousands of those units over this period of time. I use to be a dealer for them when I made custom supercharger systems many a over 5 years ago. That system doesn't even use a pump. Its use the boost pressure to **** a stream of fluid out of a MIG welding tip right on to the compressor wheel. Still no problems.
Point is, you can look aorund and find thousands of customers on the net in differen tforums running pre-compressor injection. Its perfectly fine to do.
I also posted previously about injecting it before twins screws and roots style superchargers. Their the list of or worrys. Works perfectly fie on them. Look at all the old school superchargers unning dual carbs dumping fuel right through the supercharger.
Rodney
#41
Simple, as blackbenzz said as one example, after utilizing your system for a period of time and one has their blower bearings fail due to lack of oil/rust from the spray, what happens?
I've done a lot of work with positive displacement superchargers on the dyno and at the track logging everything we can. Were pretty positive nothng is making its way out of the supercharger which is why some are not starting to inject both before and after the posiive displacement supercharger so that we can get some of this into the cylinders too. Look at EGT's. That can tell you a lot about what's going on inthe cylinders and there cmpletelty uneffected when we spray just before the supercharger. If we put that same big shot on a turbo setup and inject just before the throttle body we see EGT's drop. Especially if it has some water in the mix.
Rodney
#42
No way. I use pure methanol on the magnachargers and KB's spraying massive shots trying to get methanol to come out the bottom of the supercharger. The stuff flashes off and evaporates so quickly. Its all gone as soon as it touches the hot surfaces of the rotors or case.
Rodney
Rodney
#43
#44
Rodney
![](http://www.alcoholinjectionsystems.com/images/methanol_injection_turbo.jpg)
http://www.alcoholinjectionsystems.c...icle_info.html
#45
Rodney
#46
I have ran my AIS meth injection system on my srt6 now for 8 months and I have went through many tanks of meth with zero problems. My sig shows the results. I have ran meth on my supercharged cars for 5 years with zero issues.
#47
Post some pictures for everyone to see.
Rodney
#48
2003 porsche 996 turbo
mrphotoman this is 32krazy! from the drt-6 forum. glad to see you still around. what is the brand of meth unit you are running? im unsure of the long term effects but i am researching this for possible use in the future.
