ASP pulley guys, check your pulley!
Rating: Thread Rating: 3 votes, 5.00 average.
Old Sep 27, 2008 | 12:22 AM
M_M's Avatar
M_M
C32 AMG
ASP pulley (3 years old, 18000miles)
Rubber ring broken off
Here's the story:
Yesterday, I sent my car to my friend's garage to have a regular check. During the inspection, my friend spotted that the rubber ring between the inner and outer rings of the asp pulley has slightly pulled off, about 3-4mm, so we immidiately took it off to see what's going on, and when I first looked at the back of the pulley once it took off, I was like holy shxt.. the rubber ring's been badly damaged! if I hadn't found it out, I would have been in deep shxt for sure. Then we decided to put the original crank pulley back in, but once we fitted in the pulley, and tried to tighten the belt, we found out that the belt(oem 2908mm) was too long, I was like wtf, all the pulleys other than the code3 s/c pulley were all originals, it's supposed to fit but how come it wouldn't fit right in...! so we tried to see if there's any shorter belt available, but couldn't find any... so I suggested DIY welding the inner and outer ring together to see if it works or not, luckily it finally works out, ran it for a day, no problems so far, but i am afraid that it would create another problem soon, since it has become an non-dampened crankshaft pulley. what do you guys think?
here are the pictures:
AFTER fix: (so ugly, I know)
Old Sep 27, 2008 | 12:56 AM
splinter's Avatar
Super Moderator
GMC - Miata - Trek - P-Car
Sorry to see that.
Unfortunately, it’s not uncommon with the ASP...https://mbworld.org/forums/w211-amg/257769-asp-pulley.html
Not clear on why the OE crank/CP3 supercharger pulley combination couldn’t be refitted with your belt. Any ideas? That ASP is probably not conducive to long-term crankshaft durability, imho.
Old Sep 27, 2008 | 01:53 AM
mdncn2762's Avatar
1992 Toyota Corolla, 1994 Chevy C1500, 2002 C32, 2012 Prius, 2013 Toyota Sienna
Whoa
Thanks for posting that. Im going to check mine today.
Old Sep 27, 2008 | 10:03 AM
Eleventeen's Avatar
2002 C32 AMG
Probably better to be dampened, plus if the welds aren't placed perfectly, the pulley may now be a bit out of balance at high RPMs.
B.T.W. the reason your belt was too long is because ASP also sends a replacement water pump and idler pulley with their kits (both smaller) to make the larger crank pulley work with the stock belt and keep it from contacting the O.E.M. water pump pulley. There's no way all of your other pulleys are currently stock. You need to switch back to the stock water pump pulley and idler pulley and then the belt will fit properly with the stock crank pulley.
Old Sep 27, 2008 | 11:31 AM
CLKCLK's Avatar
03 C32 gone, 06 CLS55, 16 Tesla X
It's suck!
Good luck. I personally think it would be ok to weld like that. It would be at least as good as the last time you had it on with the rubber broken.
Old Sep 27, 2008 | 11:46 AM
boohooramblers's Avatar
Not an AMG :(
Eleventeen is correct
You should have smaller accessory pullies if you were running the ASP crank pulley. If that's the case, you'll need to put your stockers back on for appropriate belt fitting.
Aside from the aesthetic nature of those welds, I strongly suggest you send that pulley out for balancing.
i.e. Do NOT reinstall that welded ASP pulley. The position of those welds relative to the balancing 'boring' is way off.
I would go so far as to make the bold statement that anyone who installs a used (or even new) crank pulley without getting assurance that it is balanced correctly is playing with fire. I look at crank pulleys in the same way as centrifuge rotors - if you'd like to see the carnage that can ensue due to a slightly unbalanced rotor at lowish rpm, let me know and I'll send some photos!
It costs no more than ~$30 to get a pulley balanced and many machinists can do this job. PM me if you need a contact to do balancing.
Old Sep 27, 2008 | 12:45 PM
c32AMG-DTM's Avatar
2008 A8L, 2002 996TT X50, 2009 X5
Agree w/ others that you shouldn't keep running that ASP... while you're probably out of any warranty period w/ ASP, you might be able to send it to ASP, explain the situation, and try to receive a new one at a discount. In the end, I'd say get a new ASP 178mm, evosport 178mm, or LET 181mm, and get it on there ASAP.
Old Sep 27, 2008 | 12:54 PM
Code3 Performance's Avatar
C32, Cobra, 700hp Vespa
We're so sorry to hear of the issue!!
If it helps, I'll be glad to give you a sweet discount on a new pulley as I feel bad. Shoot me an email to Aaron@code3performance.com if you like.
-Aaron
Old Sep 27, 2008 | 02:03 PM
c32AMG-DTM's Avatar
-Aaron
OT - You guys offer a crank pulley now? Or are a distributor of ASP pulleys? Couldn't tell, by your comment... so simply curious - thanks Aaron.
Old Sep 27, 2008 | 02:19 PM
CLKCLK's Avatar
+1
If you have crank pulley, how much is it? COD3CRK99OFF code?
Old Sep 28, 2008 | 01:09 AM
M_M's Avatar
M_M
C32 AMG
Originally Posted by splinter
Sorry to see that.
Unfortunately, it’s not uncommon with the ASP...https://mbworld.org/forums/showthread.php?t=257769
Me neither.
As far as I remember, water pump/idler pulley were not included when I ordered from asp three years ago. I am not quite sure whether I’ve changed the water pump pulley to the smaller one, but the idler pulley is definitely in stock size, coz I just replaced it not a long time ago.
Thanks for your warning, but too bad that I don’t live in the states. I will see if there’s any mechanics in my town could do this job.
If mine can’t be fixed, I will just stick with the stock one then(if I can find a shorter belt). Since I am probably going to change car early next year, it is not worth sinking another grand for a new pulley.
-Aaron
Thanks for your kind offer, but may I know which brand do you carry?
Old Sep 28, 2008 | 11:13 AM
AMG-Driver's Avatar
SL65 R230
The Problem with the damaged rubber ring is not new with the M112 V6-Engines.
MB changed the design of the Stock-Pulley, there is a new Part-Nr.
In Germany damaged Pulleys were often changed for free by MB if they were damaged. The rubber ring mainly failed on high mileage-cars.
I checked my ASP-Pulley today and it looks fine. It is a relatively new pulley. 6 Months old 5.000 KM. I think ASP uses the new MB-Pulley now.
But it is a good idea to keep an eye on this rubber ring and the welds from time to time.
I check mine every week now... Failure could cause very bad damage.
Old Sep 28, 2008 | 12:41 PM
SLiK 350's Avatar
slk350
wow, I can't believe you are actually putting that thing back on there, its bad enough in is original form (not the best design) but to put THAT thing back on there... I hope you have enough cash lying around for a spare engine.
Old Sep 28, 2008 | 03:47 PM
60n5pt1's Avatar
2002 C32 1987 190E 2.3 334K miles and going
Murphy's Law!!!
Dump that pulley. IMHO
Old Sep 28, 2008 | 11:28 PM
M_M,
We manufacture our own products so we're able to control their quality.
Let me know if you have any further questions, I'm here to help.
-Aaron
Old Sep 29, 2008 | 10:25 PM
M_M's Avatar
M_M
C32 AMG
Thanks Aaron, but I just got a used custom made crank pulley from a nice guy.
Old Sep 29, 2008 | 11:10 PM
Thanks for the post!
We manufacture our own pulleys.
Sincerely,
Aaron
Old Sep 29, 2008 | 11:11 PM
Awesome! Glad to see you got it worked out!
-Aaron
You have already rated this thread Rating: Thread Rating: 3 votes, 5.00 average.
