Heat exchanger replacement
Old Oct 1, 2008 | 01:07 PM
KYC32's Avatar
Hi All,
I currently have my 03 C32 at the stealership and they are telling me to replace the heat exchanger will require approximately 6 hours of labor. I have an extended warranty and they are only willing to pay for 2 hours of labor, stating that is what all the manuals say is the standard for this car.
Does anyone have any experience with this, or know what a true "typical" labor time should be? I want to have the proper information to take to either the warranty company or the stealership to dispute whoever is off base here.
Thanks!
Old Oct 1, 2008 | 01:11 PM
moosejaw's Avatar
none
An independent shop can do it in about 2 hours. I pidi 100 bux.
For 6 hours it should include dinner and ballroom dancing session with Kim Kardashian.
Old Oct 1, 2008 | 01:52 PM
loungn14's Avatar
SPONSOR
From: Houston/ Austin /Toronto / UAE / Minneapolis / Orlando /Cincinnati
Eurocharged Performance ML63 and TT lambo
I did it myself in 2 hours.....6 hours is a joke.
Old Oct 1, 2008 | 01:56 PM
c32AMG-DTM's Avatar
2008 A8L, 2002 996TT X50, 2009 X5
+1
With a helper, it should only take a couple hours. Trying to do it yourself would be a major PITA because of the bumper removal and reinstallation.
Old Oct 1, 2008 | 02:23 PM
saer1one's Avatar
2002 c32 AMG 2012 c250 Coupe
but if it comes with dinner and ballroom dancing with kim kardashian, maybe a her second video.. i think i would pay the man for the six hours..!! hey loungn14, does LET still have the johnson pumps with the heat exchanger deal..?
Old Oct 1, 2008 | 02:29 PM
KYC32's Avatar
Thanks all. I'll have to be sure to question about why it takes them so much longer than apparently everyone else can do it.
Old Oct 1, 2008 | 02:54 PM
savvy75's Avatar
2008 BMW 135i
upgrade!
If you are going to replace the Heat Exchanger, go with the LET Heat Exchanger and Johnson Pump. (might as well upgrade)
Code3 Performance's Avatar
C32, Cobra, 700hp Vespa
I think 6 hours is a little too long. It should take 2-3 I believe.
-Aaron
Old Oct 1, 2008 | 05:44 PM
Zeppelin's Avatar
C32
Why are they telling you to replace it? Is it leaking? Is there a puddle in front of your car.
Old Oct 1, 2008 | 08:27 PM
c32AMG-DTM's Avatar
Hmmm... I read it that the OP requested a labor quote to replace the HE (presumably, with a larger aftermarket unit) and the dealer quoted 6 hours of labor... maybe KYC32 can clarify
Old Oct 1, 2008 | 10:14 PM
Eleventeen's Avatar
2002 C32 AMG
The C class bumper is actually very easy to remove compared to other cars. I can take it off in under 20 minutes now. Reinstallation is probably just a bit longer. The heat exchanger should pop out in about 5 minutes once the bumper is off. It looks like a much longer job than it actually is; they've probably never done it before. Two hours is much more realistic.
Old Oct 1, 2008 | 11:03 PM
moosejaw's Avatar
none
youre getting hosed my freind
print out this thread aand show them this
Old Oct 4, 2008 | 12:00 AM
TheMadDutchman's Avatar
2001 E55 Estate
Just installed a Code 3 Performance HE today.
2 to 3 hrs is fair for an experienced tech.
Old Oct 4, 2008 | 12:07 AM
c32used's Avatar
LET C32 2002
+1
NO MORE THEN 2 HOURS MAX!
Old Oct 4, 2008 | 12:09 AM
c32used's Avatar
LET C32 2002
Originally Posted by c32AMG-DTM
+1
Without a helper still within 2 hours Ofcourse if you know what you are doing...
Old Oct 4, 2008 | 06:26 PM
Newzchspy's Avatar
PLAID
Which Code III Unit??? I've been waiting for word on when to order that and several other items???
Old Oct 4, 2008 | 06:51 PM
c32AMG-DTM's Avatar
Very true, c32used - when I changed mine, I'm approximating anyway, b/c of changing the HE and the Johnson pump at the same time. Plus, had never attempted to R&R the bumper before. Plus, needed to run out to the hardware store for some hardware, SS hose clamps, etc. etc.
