Qauife LSD for your C32 or C55 at a special price of $1395!
07 RS4 sold, R53 Cooper S, 2008 Cayman S, 2012 GTR
Yes the quaife LSD's are back in the states, both the QDF7V and the QDF9V are back! Both are priced at $1395.
The smaller QDF7V will be ready to ship in 10 days, call us today to lock in your order at this special low price!!!
depending on what your shop is going to charge you, for your C55, i would guess, 8 to 12 hours.
You can get the install done by either Richard at dyno-comp, or john at goodspeed.
What about the SLK32 -- same housing? Will the QDF7V work?
From my understanding its a different casing, I believe someone tried to do the swap and you needed to buy the rear casing, axle and a few other items.
I will look for the information for you.
I'm not completely sure, but I can find out in a few hours.
Most C32, and C55 owners who have done the LSD would say this is one of the best mods you can do especially if you track or do canyon runs in your C. Your not going to get a performance upgrade per say in terms of ad more power then what you originally had, however what you will be able to do is utilize all power, to both wheels.
i'm sure a few guys here who have installed the quaife, can give you there own personal testament.
2003 C-Class Sportcoupe
![action](https://mbworld.org/forums/images/smilies/action1.gif)
I still have all the parts from the swap lying in my garage.
Both the C320 and SLK32 have a smaller transfer case than the C32 and E55. C32 uses a 210mm ring gear in its case and C320/SLK32 use a 195mm ring gear in their case. I tried to do the swap and I couldn't get the electronics to work.
Mechanically, everything was fine; Quaife worked like it was supposed to. So I had to put the old case back in with a Phantom Grip.![action](https://mbworld.org/forums/images/smilies/action1.gif)
I still have all the parts from the swap lying in my garage.![nix](https://mbworld.org/forums/images/smilies/nixweiss.gif)
Pshek,
Can you give me a bit more detail on your statement:
"I couldn't get the electronics to work. Mechanically, everything was fine; Quaife worked like it was supposed to."
What electronics were not happy? TC, ESP, both? Did the car go into limp mode?
Thanks in advance!
Cheers,
KrzyFast
Thanks in advance!
Cheers,
KrzyFast
Pshek,
Thanks in advance!
Cheers,
KrzyFast
Thanks in advance!
Cheers,
KrzyFast
Mercedes-Benz W203 C230k
Guys! I need your advice. I've got a 2004 C230k (restyling version) with manual gearbox and I've just ordered a Quife differential for C32. Will it fit and work properly? Any additional parts needed?
2005 c55amg, 2000 clk430, 2002 clk55amg, 2008 clk63amg black series
Kleemann LSD's are 900 bucks............
88 BMW M3, 11 BMW M3 Vert, 04 Porsche GT3
Anyone with Kleemann LSD installed in their car? How much do you guys think it would cost to get a LSD instaleld on a 2002 C32?
1 Post
2019 E63s AMG
Example around a turn /w the Quaife LSD on my C55 AMG
No one wheel spin
... just powering through the turn and out through the second turn... unimaginable difference...
http://videos.streetfire.net/video/M...-S7_689701.htm
No one wheel spin
![Wink](https://mbworld.org/forums/images/smilies/wink.gif)
C32 ///AMG
No one wheel spin
No one wheel spin
What's with the passenger headlight turning on coming into the first turn?
