Evo pulley & LET Pulley (Are they somewhat similar)
https://mbworld.org/forums/c63-amg-w204/267109-evosport-releases-power-pulley-system-63-amg.html
I was wondering why LET ended their so famous 185 pulley and just a short while, Evosport came out with this very similar design pulley.
Could they be manufactured by the same company?? Some sort of exclusivity, patent issues or something else stopped LET from offering them again??
Any thoughts??
https://mbworld.org/forums/showthread.php?t=267109
Any thoughts??
Only time will tell...
Why would Evosport offer this type of pulley for the 63 engine? Its NA not SC unless its lighter crank pulley
They do appear identical.
I think while the transition is happening with LET I think certain products may need contracts change hands and until then it may cause issues with selling product.
Recall from a thread mentioning that he wil not sell hardwares, only for tuning.
From LET website, all pulley listings are gone.
Any thoughts??
LET's pulley design is similar to evosport's, with the exception of the LET crank pulley being larger, of course.
Of all the MB pulleys we've come across (which believe me is alot, everything from the last 20 years) The C63 is by far the smallest and is a totally unique design unlike anything else, same is true of the 65 pulleys (7 rib design is unique to the 65s due to the power they make). I would not recommend decreasing that diameter anymore than it is but again its up to the consumer. I have a feeling MB took some pages out of the aftermarket to extract even more power out of that 6.3L engine, The OEM is definitely a unique design.
As far as weight, I am not sure how much the one above weighs but that would be interesting to find out, I do know the stock C63 pulley is similar to most other MB pulleys (around 7 lbs roughly). hope that helps.
The design of our pulleys and the design of the Evosport pulley have been around for many, many years and is nothing new.
They came from the same place at first.
He's correct. I had a 69 Trans Am and we would drag the car. On track days, we'd remove the "belt" and run crank only, played hell on Power steering and brakes, BUT it sure did release some power. It was very common in the "old days" to entirely remove the belt at the drags (and worry about cooling later); Thats why some guys would tow or push their cars to the line, start em, drag em and turn em off at the end and two em back to the pits!! Its worked then.
Jerry probably has an ace up his sleeve. I'm sure we're all going to be amazed [again] in no time.
