is this the correct transmission dipstick?
Old Oct 29, 2008 | 11:05 PM
TemjinX2's Avatar
03 g35 coupe...........02 c32 Sold
Hi guys,
i'm probably going to do a complete maintence overhaul on my car. Heat exchanger, johnson pump, behr radiator and transmission fluid change.
I just wanted to see if this is the correct dipstick for the c32. The link just say mercedes transmission from 99-04.
http://cgi.ebay.com/ebaymotors/Merce...spagenameZWDVW
Old Oct 30, 2008 | 08:32 PM
Eleventeen's Avatar
2002 C32 AMG
I don't remember the P/N, but it looks identical to mine
Old Oct 30, 2008 | 08:43 PM
TemjinX2's Avatar
if its fits, can i just leave in there like a regular dip stick or do i have to put back on the oem seal?
Old Oct 30, 2008 | 09:04 PM
nick 55's Avatar
GL550, C55, 335i Coupe, vintage Mustang
Gotta put the cap back on. That dipstick is about 12" too long, and doesn't have a dust seal. It is just a special tool.
Nick
Old Oct 30, 2008 | 09:28 PM
TemjinX2's Avatar
got it thanks
Old Oct 30, 2008 | 10:14 PM
1qikctr's Avatar
Merc power
Nick
Old Oct 30, 2008 | 10:56 PM
splinter's Avatar
Super Moderator
GMC - Miata - Trek - P-Car
Mine is stamped 140 15 21, although its MB part number is 140 589 15 21 00. Excellent price, incidentally.
Radiator DIY for when you're ready.
Old Oct 31, 2008 | 12:21 AM
Eleventeen's Avatar
2002 C32 AMG
F.Y.I. you are also supposed to heat the trans fluid up to 80*C when you measure it. The dipstick is calibrated for the amount of expansion present at that temp. I just point my I.R. thermometer at the transmission pan. Also, when you insert the dipstick, go very carefully. It actually rests against the bottom of the pan and measures the level from the bottom up, as there is no stop on the dipstick. That little plastic piece on the measuring end WILL deflect when it bottoms out and ruin your measurement if pushed too hard.
German engineering... yeah, nice
Oh, one more thing: don't make the same mistake I did when I first got the car. The tube down behind the engine is for the tranny. The tube coming up next to the supercharger is for the engine oil.
Old Oct 31, 2008 | 12:36 AM
c32used's Avatar
LET C32 2002
Good info hey TermjinX2 let me know if it works I want to get one also
Old Oct 31, 2008 | 04:51 AM
TemjinX2's Avatar
actually the dip stick idea came to me when i was reading your diy.
I have the johnson pump, new behr radiator, and a code3 heat exchanger on the way. Hopefully aaron can ship it out to me by monday. I was thinking i might as well do the whole thing at once..maybe do a transmission change while i'm at it. Basically do a complete maintence overhaul.
Right now i have a lot of free time since i'm waiting on my job title to transfer to the other company.
John, let me know if you can still help on the installs. I'd rather have a pro help me then me trying to stumble through it.
-Mike
Old Oct 31, 2008 | 12:04 PM
splinter's Avatar
Super Moderator
Originally Posted by TemjinX2
...let me know if you can still help on the installs...
Of course. PM sent.
Old Apr 27, 2009 | 01:11 PM
Vomit's Avatar
2002 C32 Black/Charcoal
Is that black dipstick plug on the right side, slightly below the middle of the photo the transmission dipstick tube?
Old Apr 27, 2009 | 01:42 PM
TemjinX2's Avatar
the black plug on the right is where you suction out the oil from. There transmission plug is the black plug with a red button attached to it. Its just below the left air box.
Old Apr 27, 2009 | 01:49 PM
Vomit's Avatar
Got it, thanks!!!!
So, the tranny tube is the one with the plastic cap that says something like "Mercedes Shop Only" or the sort.
I still can't find the ******* oil drain plug on the underside of the car. Am I blind or what????
Also, TemjinX2, you obviously have already been through this. . . Has anyone developed a full-time tranny and oil dipstick (actual functional, trustworthy measuring tools which are installed full-time?) I would really love to have a couple of real dipsticks on the car!!!
Is the dealer the only option for the tranny fluid?
Thanks again.
Old Apr 27, 2009 | 01:54 PM
TemjinX2's Avatar
yeah thats sounds right...i dont remember what it said but i remeber it had a red tab. You push the tab to break the seal, remember to keep the red tab, since you reuse it.
i dont know where the oil drain plug is, you might want to PM splinter, he's more knowledgable.
As for the full time dipsticks, i have no clue..lol. I used the electronic for the oil and the ebay dip stick for the tranny.
Old Apr 27, 2009 | 02:35 PM
320 dreamer's Avatar
2003 porsche 996 turbo
the red tab is only there if the dipstick tube has previously been opened. if it hasnt then the locking tab is black and non reusuable. the red tab replaces the black tab
oil drain is on the bottom of the tranny pan. if you break the output hose loose then you can drain the oil from the pan and torque converter. all told approx. 7.5 qts. the way its done is crack the line insert in drain jug. fire car up run 15 secs shut off. should have approx 3 qts in jug. drop pan and replace filter and clean pan and add new gasket. dont forget the magnet in the pan. replace fluid and repeat going through all the gears. shut off. should have 4 qts in jug. replace line bring up to temp and check level. take care to torque tranny bolts from the middle out as the rubber gasket can cause you to overtighten at 1 end and cause leaks.
check old fluid for coolant as its a common issue with the m/b radiator.
if you are running a 722 tranny you can use sprinter / crossfire fluid for the tranny. cost is approx 4$ per qt cheapper than m/b
Old Apr 27, 2009 | 03:16 PM
Vomit's Avatar
Thanks alot!
Not sure what a 722 tranny is. I have the stock 2002 C32 five-speed automatic. Is this the 722?
Old Apr 27, 2009 | 03:29 PM
TemjinX2's Avatar
yeah its the name of the transmission
Old May 16, 2009 | 03:20 PM
dkflipse's Avatar
C32 AMG
Anybody know what a ballpark price is on a tranny flush at the dealer? My local dealer won't quote prices over the phone. They require an "inspection" first.
Old May 16, 2009 | 04:39 PM
TemjinX2's Avatar
lol my dealer quoted me $460 for a flush. i gave him the middle finger and did it on my own with splinters help of course. I believe its a little over $100-150 in parts. I'm including the 10-12qts for a full flush, the filters and dip stick. If you only doing a change i think you only need 4qts, i cant remember exactly.
i'm probably gonna do another transmission fluid change with my next oil change, just try try to get some of that older transmission fluid out of the torque converter.
