thinking about adding 100lbs to my car
The best thing to do would be to keep modding your C55 and also find ways to reduce weight by a few hundred pounds, that would be the best option. just a thought
i know originally LET was just going to tune with the stock ecu. You should PM jerry and see if he can remote tune it, if you datalog the car with a wideband.
Just spoke with Cory at Kleemann today. Eduardo (MBMexcio) is having his TT C55 project buttoned up and the bill is near $100K!!! Of course this includes a DTM wide-body but the CR had to be lowered significantly, not to mention forged internals, etc...
I asked him about doing a Brabus style 6.1 S conversion while still keeping the Twin-Screw but he said they are not set up for that.
He then suggested I wait for the completion of Edwardo's project which they plan on building a economic kit for if there is enough demand from C55 owners.
There is also the 6.1 displacement increase option similar to Brabus which can be coupled with a SC kit. This option may be easier for ECU tuning and yield equal or better power results.
This is where the quality of the tuner comes in. People turbo s2000's all the time easily hitting 400whp-500whp. S2000 compression ratio is 11:1:0.
psi also has nothing to do with the amount of power you make. 6psi on a smaller turbo will yield different whp then 6psi on a larger turbo.
The difficult part will be the tuning and how much power can the stock block take before it needs to be upgraded. I said this in other threads about the c55. Its the block thats going to hold you back. I would build the block...just for piece of mind.
The only real benefit to tt is that you can have a smaller turbo for the low revs fully spooned while the second turbo is spooning for the higher rev's. It was a common technique in the past to reduce turbo lag.
Turbo tech has advanced pretty far since those times with the newer ball bearing turbos.
Even on a 1.8L integra motor, a gt30 turbo was basically fully spooned by 2000rpm on a 8200rpm redline. Hence why hondas respond so well to turbos, lot of revs to stay in boost for a long time before shifting.
Given you have a 5.4L motor, even out of boost the car is going to have a decent amount of power off the line.
But if you thinking of lowering your compression by switching out the pistons, you might as well just built the whole block since the engine is out or try to source a used e55 block from a wreck or something.
https://mbworld.org/forums/vendor-group-buys/269681-kleemann-kompressor-special.html
Hooleyboy, if you are serious about keeping the C55 and making the "fastest" C55 on the planet, I'd go with the Kleeman Supercharger and headers. This will automatically put you in another league in terms of acceleration and straight line speed. A proven tuner with a long track record. They've been supercharging the M113 for a LONG time, so there should be no (or minimal) unpleasant growing pains or unexpected problems you would have with any new tuners trying new products.
Before I got my C55, I was seriously thinking about supercharging my previous C240 with Kleeman.
Whats there to think about??
http://sfbay.craigslist.org/eby/pts/926209085.html
Mercedes Benz Supercharger HPS E55 E430 CLK430 CLK55 Brand new 466HP - $4000 (dublin / pleasanton / livermore)
Reply to: sale-926209085@craigslist.org [?]
Date: 2008-11-19, 4:24PM PST
Selling brand new HPS Supercharger system
Selling brand new HPS Supercharger system. Designed for W210 mercedes Benz E55, E430, CLK430, CLK55, ML430, ML55, etc V8 engines.
Everything is packaged in original wrappings in the box.
Call Wali 925-787-3713
High Performance System team members have over 300 years of experience in aerospace, commercial, and automotive manufacturing / engineering. We have the expertise in material selection, manufacturing, casting techniques, and machining methods, coating, plating, and assembly to produce the highest quality cost-effective supercharger available.
High Performance Systems manufactures every component the same high standards as Mercedes Benz. All components are cast from high-grade aluminum alloy or stainless steel and machined with the state of the art tooling use CNC Machining Centers. Our fasteners are made of high-grade materials for an OEM appearance. Components such as hoses, belts, and idler pulleys are manufactured by leading suppliers in the Mercedes field.
High Performance Systems have teamed with the Eaton Corporation and Magnuson Products, to offer a highly technical and efficient supercharger system. The Eaton supercharger is the virtually unanimous choice of all original equipment manufacturers. The Eaton compressor is used on the SLK, C – Class and the Jaguar R series engines. Jerry Magnuson, the exclusive distributor of the Eaton supercharger brings over 35 years of supercharging experience to these ventures. Magnuson’s R&D team combines more than 60 years of system designing experience with state – of – the – art engineering with computer aided design and fabrication CNC Machining technology. This in turn has developed one of the most durable and efficient supercharger systems in the automotive after market world. Our other partners include automotive experts that are recognized for their achievements in the automotive industry. All our components are proudly made in the USA!
