fuel gauge errors
C32
fuel gauge errors
Before anyone replies with STFF, I've done exactly that and found this to be a fairly common problem with C classes here.
For me specifically, I have an 04 C32 and it has been in the shop several times for an erratic fuel gauge. The dealer said they've replaced the cluster, the SAM, and updated the software but none of those addressed the problem.
Has anyone had a similar headache and what was your fix?
C32 AMG
Mine JUST started doing that! The last 2 times I filled up it reads as 3/4 full or just a tad over. I had searched for an answer to see if this was common and didn't find anything either. I was hoping it would correct itself in time.
I was going to run it all the way to fumes and then fill up and see what it does. If it's still acting weird, off to the shop....again.
I'm actually kind of glad to see someone else is having the same issue. If I end up having to take it to the shop over this, I'll pass on anything they do. However the answer is always to troubleshoot with new parts and repeated trips back for the same issue(s).
![smash](https://mbworld.org/forums/images/smilies/smashfreak.gif)
i had this problem. if i remember correctly, the dealership replaced the "bob" or some part of it that detects how much is in the tank. a faulty bob or w/e part may cause faulty readings.
Fuel lever sender problems seem to be common to all MB's after about 40 to 60k miles. I had the dealer replace both of the integrated fuel pumps, fuel level senders and fuel filters contained in my C55 gas tank under the OE warranty before it expired.
This was also a problem on my 99 C43 and 87 300E. However, on each of those cars it was easy to replace the fuel level sender myself, not so on the C55 (the gas tank has to be dropped).
C32 AMG
1 Post
2007 GL450 2005 C55 2002 C32 sold 2001 ML320 sold
Fuel cleaner?
I had the same problem in my 2002 C32, and a buddy told me that it may be gunk buildup on the fuel sender. I did 2 things to fix it. 1) put a bottle of fuel system cleaner in the next tank, and 2) switched to a different fuel manufacturer for the next 5 tanks. This has worked for me so far.
Hope it helps someone.
2002 C32 1987 190E 2.3 334K miles and going
My needle starts going down slow at just below the quarter mark (3/8?) and stays there with about 2-3 gallons left. Eventually, the 'visit refuelling station' prompts lit up.
One time coming in at a fastfood drive thru the gage read less than 1/4, after five minutes waiting for my order, the 'visit prompt lit up. I ran out of gas 1/8" of a mile later.![EEK!](https://mbworld.org/forums/images/smilies/eek.gif)
Also, even after you fill up, the needle stays between 1/4 - 1/2 initially and after a couple hours of driving, slowly shoots up to almost full tank.
Any cheap and quick fix for this?
![crazy](https://mbworld.org/forums/images/smilies/crazy.gif)
C32 AMG
Don't know any after market fuel cleaner additives since, I believe, MB doesn't recommend.
but check out this site:
http://solutions.3m.com/wps/portal/3...l_Sys_Cleaner/
C32
As for gas brands, I've always filled up at Chevron (Bay Area) or Shell.
As for the latest, my SA told me MB Engineering needs to send them a software update for my car. Has anyone had something like this before?
C32 AMG
