ecu removal, help please
Old Nov 11, 2008 | 02:44 PM
genome's Avatar
05 c55, 08 600rr
2005, c55
ive gotten the connectors off. very simple, easy.
for the life of me i can not remove the ecu. im holding onto it from the screw housing on the side. ive pulled up, left to right......
ive even tried using small metal rods to leverage it out, no use.
ive bust open a finger and bleeding from another one.
any tips?
Old Nov 11, 2008 | 03:33 PM
60n5pt1's Avatar
2002 C32 1987 190E 2.3 334K miles and going
I have a C32. With the wiper at twelve, after disconnecting all series of connectors, you should just be able to lift it up the assembly housing.
Old Nov 11, 2008 | 03:38 PM
genome's Avatar
05 c55, 08 600rr
ive been trying like hell. nothing seems to budge it.
not sure if a c55 has a different removal process, but its not budging. ive gone as far as using a small wrench with a slightly angled end to leverage it against the screw housing and against the black plastic molding case the ecu is in. not even a mm movement. it really feels like theres something holding it in, but i was assured by a ecu tuner/flasher that it should come out with some elbow grease.
anyone with a c55?
Old Nov 11, 2008 | 03:41 PM
TuneTime's Avatar
Former Vendor
Any AMG Thats Around..
there should be 2 clips on either site of the ecu....
Old Nov 11, 2008 | 03:44 PM
genome's Avatar
05 c55, 08 600rr
two clips? could you please elaborate?
Old Nov 11, 2008 | 03:47 PM
genome's Avatar
05 c55, 08 600rr
thanks!!!! i found th tqwo clips, but still having a tough time with the removal. but at least i know what to do.
typos from bustewd finger!!!!
Old Nov 11, 2008 | 03:54 PM
genome's Avatar
05 c55, 08 600rr
got it out!!! thanks tune time!!!!
Old Nov 11, 2008 | 04:02 PM
TuneTime's Avatar
Former Vendor
no prob.... asking is better then breaking!
Old Nov 11, 2008 | 04:09 PM
60n5pt1's Avatar
Ooops fugawdaboud the clips! glad you got it out though
