Problem with self levelling Xenons
Been a while since I posted. I have a 2001 C32, UK spec with original equipment Xenon headlamps.
In the last few days the auto self levelling in the lamps have stopped working. The result is that the beam pattern is about 5 yards in front of the car making driving in the dark very difficult.
When I switch the headlamps on, they momentarily dip down and back up, but they are not coming up as much as they should do.
Does anyone know if these lamps can be serviced?
Cheers
Alan
I'm having the same problem with my 05 C55. My drivers side low beam would not level sometimes and be pointed at the ground while the passenger side is fine.
this happens once a month maybe. i'm unsure whether the motor in my headlight is broken or the sensor for the autoleveling is broken.
since both of your lights are pointed at the ground and your lights go up/down to start, i'm more inclined to say that maybe your sensors are malfunctioning.
When hooked up to STAR it will tell you the fault
It seems lowering the car meant that the control arm fastened to the front anti roll bar ( the one television refers to ) was no longer working due to having to go beyond it's range of adjustment when trying to set the headlights to the correct level.
the fix was to have a new control arm fitted which was modified to work with the cars lowered ride height
Thanks everyone, this gives me the necessary info to go back informed to the dealer and get it fixed at their expense.
Cheers
Alan
