New LED Tails... Will these fit?
Subscribe
Dec 8, 2008 | 12:13 PM
Hey guys.
I am looking to pick up a set of LED Tail lights and these look pretty good. Can anyone assure me they are going to fit?
Thanks for the help.
http://cgi.ebay.com/ebaymotors/ws/eB...3AIT&viewitem=
Reply 0
Dec 8, 2008 | 02:08 PM
Yeah they should fit fine , You should look at the s class style leds if you like that it fits too.
Reply 0
Dec 8, 2008 | 02:12 PM
They will fit but you might have to do some wiring change to the lights. I had to, to get my set to work properly, I bought the Eagle Eyes brand.
Reply 0
Dec 8, 2008 | 02:25 PM
Quote: They will fit but you might have to do some wiring change to the lights.
+1 if u have 05-07 W203...
Reply 0
Dec 8, 2008 | 02:56 PM
Quote: They will fit but you might have to do some wiring change to the lights. I had to, to get my set to work properly, I bought the Eagle Eyes brand.
Where did you pick up your Eagle Eyes?
Reply 0
Dec 8, 2008 | 10:06 PM
Quote: Where did you pick up your Eagle Eyes?
EBay!
Reply 0
Dec 9, 2008 | 04:16 PM
look very closely at the LED pattern. Two of the horizontal strips of LEDs are not continous because each uses a spot for an LED as a mounting hole.
so, it would look as if one LED is out on these two separate strips. I believe its the second from the top and the one above the bottom strip that have this feature.
otherwise, they look cool.
I had a problem with mine from the start. Some LEDs went out after installing them.
The vendor even said it needs to be 'shocked' with a 24V to break in the LEDs!!! duh
I decided to order LEDs from superbright and have a friend of mine replace the bad ones and solder the new ones.
Because the LEDs I got were a little different from the aftermarket, the LED light intensity is different from the others.
i should have sent them back for an exchange but too much hassle.
Oh and these are Eagle Eyes.
I also smoked them (Vans paint) lightly to to darken the clear horizontal back up light strip.
Reply 0
Dec 9, 2008 | 06:15 PM
yeah i've been eyeing them too. Mugenx has them on his car and they look pretty good in person.
I just couldn't justify spending $300 on tail lights.
Reply 0
Explore
Subscribe
Currently Active Users (1)
