Install Help Needed
I just picked up some parts for my C55 and needed a little help on the installs.
1. K&N Air Filters (I have looked but cant find anything)
2. CLK Grille (I have the grille. What else do I need and how to do it)
Thanks in advance.
If your airboxes are like the C32, it's just a matter of removing the screws from the airbox and replacing. The grill comes out fairly easy too. The grill takes less than 5 minutes and airboxes I'd say five minutes each- max. It's really not that bad.
I was under the impression that I needed to purchase a different latch for the hood... Is this correct? I already have the flat hood badge.
So the only part I will need is the hood latch?
No problem, yes all you need is the hood latch. You need to change the piece of plastic that goes from the radiator support to the grille, which should come with the grille. If you you the flat emblem make sure that the bottom of the emblem the (screw) isn't to long and runs into that plastic piece. If it does simply open a small hole in that small plastic grille support. Then the hood will close with no problems. Also depending on the grille you will need to remove the chrome strip that is on the hood about six plastic nuts no biggie.
http://cgi.ebay.com/ebaymotors/Merce...t_33923wt_1135
https://mbworld.org/forums/c32-amg-c...ood-badge.html
Thank you so much for that... I dont know why that didnt pull up when I did my many searches....
Thanks again.
http://www.installuniversity.com/mb/...airfilter.html
