Went to the track... new 1/4 mile results!
Current setup:
ASP 178mm pulley
K&N's w/ Code3 intake mod.
Code3 Heat exchanger
Code3 Intercooler core
Meziere circulation pump
Moroso reservoir
H.F. Cats
Trunk mounted battery
L.E.T. tuned (older tune still mapped for 22psi+ of boost for stacked pulley setup)
245/40-17 Firestone Fusion ZRi tires (25psi)
Temp: 35*F
Best run results:
60' - 1.811
330 - 5.201
1/8 - 8.012
MPH - 87.42
1000 - 10.424
1/4 - 12.472
MPH - 110.39
The car is actually faster with only the ASP since there are no fueling issues. I need to have Jerry re-flash my ECU with the newer version of the LET tune.
Currently, the tune isn't even suited to my mods, since it was originally done with an additional 4 pounds of boost in mind.Here's a link to my results with the stacked pulleys:
https://mbworld.org/forums/c32-amg-c...eave-room.html
Current setup:
ASP 178mm pulley
Moroso reservoir
H.F. Cats
Temp: 35*F
Best run results:
60' - 1.811
330 - 5.201
1/8 - 8.012
MPH - 87.42
1000 - 10.424
1/4 - 12.472
MPH - 110.39
Moroso reservoir
H.F. Cats
L.E.T. tuned
In my mind, i always thought with a lower pulley plus the C3pulley plus a tune will get C class in to a 12 flat or high 11's. Nevertheless, Good pass! like all other positive comments.
Moroso reservoir
H.F. Cats
L.E.T. tuned
The 185 and 191 are putting out better numbers for what its worth..
While a bit counterintuitive, the 178mm crank pulley set-ups do seem capable of laying down 1/4 mi times every bit as good (in some cases better) than the larger pulley variants
Fongflex's 12.388 is several years old and yet is still the "all-motor" C32 record - which was accomplished with a Renntech (i.e. 178mm) pulley and tune AFAIK. Eleventeen's 12.472 on a 178mm crank pulley is only a whisker slower than Loungn14's 12.430 from a 185mm crank pulley (non-nitrous, I think?), and is FASTER than Jerry's old car's best time of 12.490 (boat-load of mods, 185 or 192mm crank pulley, and nitrous).
It would be interesting to have a thread with a list of the best drag results, broken into categories like "overall" - "all-motor" - "stock" etc. (like what was created on the w211 AMG forum). The sticky we already have gets bogged down with conversations, hampering it's usefulness.
Oh yeah - Eleventeen - since I didn't already say it, congrats!!! That is a monster run by anyone's measure - to have done it on street tires, without optimized tuning/plugs/etc, is phenomenal - nice work indeed.
ASP 178mm pulley
Moroso reservoir
H.F. Cats
Temp: 35*F
Best run results:
60' - 1.811
330 - 5.201
1/8 - 8.012
MPH - 87.42
1000 - 10.424
1/4 - 12.472
MPH - 110.39
You need to pop on the OEM's and make some passes so we can see that sucker go! I bet you'd drop at least 2 tenths unless they are super light or something; your trap speeds are nice
Great run!!! Nice DAs too!! AFAIK, thats a great run on all motor. Fong's was all motor and I think Jake's was too (with cryo??). I ran a 12.7/110 all motor with ONLY a a Jerry Tune, a Code III intake and a Code III pulley on stock Michelin PS II's at 30 PSI, so there is some credence to the argument that all we need is the pulley (one) and a nice tune to get the C32 into mid 12s. I really don't see the advantage of going with stacked and then dealing with CEL and fuel issues.
Glenn
Na, I am going to run the stockies next time with some nittos. Strange thing is, I swapped rims with jerry's 18" monolights, but could not hook up at all. We assumed the added weight helped the hookup.
And superlight...not so much....monoblock reps are extremely heavy.
Glenn
I am still only trapping 110 MPH, so I think my good times are in the short track. I was consistently cutting 1.8xx 60' times on Saturday with a 1.80 my very first run and a 1.81 on my fastest run. The funny thing is, my fastest run was my last run. I made 25 runs on Saturday (only about a dozen cars there) and almost all were 12.5xx, then I finally hit the 12.47 after literally 45 minutes of hot lapping. Not sure if the consistent power is due to the 35*F temps or the fact that my ENTIRE intercooling system has been upgraded.
