CALLING all racers
Old Jan 25, 2009 | 04:15 PM
mlg's Avatar
mlg
06 C350 sport 6MT
CALLING all racers/ trackers
anyone add a front strut tower, and what were the results??? thnx, mlg
Old Jan 25, 2009 | 04:42 PM
advans's Avatar
C55 ///AMG, 535xi
i dont think they make it, I think Wiechers made like ONE.
Old Jan 26, 2009 | 02:31 PM
shocker21's Avatar
2005 C320
strut bar
Does it look like this one, thought about buying one but never did.
Old Jan 26, 2009 | 02:46 PM
jturkel's Avatar
02 C32 AMG
couldnt find a strut bar, but found a sway bar from evosport:
http://www.evosport.com/product/prod...RS.SUS.M03.W01
Old Jan 26, 2009 | 03:33 PM
RedBull's Avatar
CLK550
Strut tower braces don't really make much difference. You're better off upgrading your sway bars. Now if you upgrade the sway bars and add coilovers, then the strut tower braces are worth adding to eek out that last little bit of improvement. On a stock suspension though, don't waste your money.
Old Jan 26, 2009 | 03:44 PM
jturkel's Avatar
02 C32 AMG
+1.....evosport also carries the correct coilovers or springs for your (the OP) vehicle
Old Jan 26, 2009 | 04:37 PM
MRAMG1's Avatar
S600, GL450, GLC 43
Waste of money, time, and weight.
Only required when you run ludicrous front spring rates for road racing, which NOBODY currently makes for the C32.
See yeah
Old Jan 27, 2009 | 04:56 PM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
See yeah
+1 and it also makes a ***** of effort when it comes to changing filters.
Carlsson did make one tho. silvac32 has it. discontinued.
Old Jan 28, 2009 | 11:32 PM
mlg's Avatar
mlg
06 C350 sport 6MT
have added kw coil overs and VERRRRRRRY sticky/stiff tires- dunlop starspecs , have also corner balanced and set toe to zero, -1.5 camber, the car handles great, but still eats up the outer corners of the front tires, i may need stiffer sways or more neg camber, please chime in thnx, mike
Old Jan 29, 2009 | 12:18 AM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
how low is your kw setup?
i have pretty even wear on my front tires at the ride height i'm running. 2/3 to 1 finger gap on the front. don't remember what my front camber spec is tho.
Old Jan 29, 2009 | 07:46 PM
mlg's Avatar
mlg
06 C350 sport 6MT
front gap is about 1 finger, rear gap is no finger, ie tire and fender are even
