power difference between code3 pulley and LET 185?
i have had the code3 pulley for around 6 months, now i'm searching for more power, installing ASP pulley together with the code3 seemed to be problematic (overboost issues etc) so I'm thinking to jump straight for LET 185MM. how much more power will the 185 make over code3 pulley?
Not sure if I'm gonna dyno it before the revised tune, but definitely after the tune.
Regardless, it seems as if people are really happy with it.
The C3P vs. 185mm is about the same as a 178mm vs. 185mm. If I can ever find a dyno shop within a 300 mile radius, I will be sure to run some numbers. My tune (LET)was matched to everything I have and set to run on 93 Oct.
All cars were SRT-6's and had aftermarket intakes
what kind of dyno was this?
res delete you shouldn't see power (maybe 1whp and slight weight reduction) unless you have headers
and yes, all cars are going to be different....it would be best (or ideal) if all mods could somehow be tried out on the exact same motor in the exact same car for the best results as to actual gains with mods.
Ive taken many M3s when I was stock. From low gear rolling to high gear highway rolling and off the line.
I dont think you should have a problem beating it.
How much boost is required to trigger the overboost CEL?
The car has so much torque that when I get a good launch on drags, it thinks it was rear ended and unlocks the doors......makes for fun with friends..
He has the Renntech pulley and I have the ASP (no spray), both 178mm...
Perhaps....
yup, got one that stays in the glove compartment
