Green Filter Install on C55
Former Vendor of MBWorld
C55,SL55,C63
Thats no way to treat a new member, Welcome to the forum.
Take the front cover engine cover off (engine cover has 2 parts) once that is off (just holds in with clips and can be done by hand). Then pull up on the front of the airbox and the intake will pop off.
Once you have the airbox off flip it over and unscrew the screws on the filter housing to expose the air filters. once you have exposed the air filters the new filters will just drop right in. Make sure the filter is completely in and then reinstall the back filter housing.
when you are putting the airbox back on the motor Line up the rubber intake gasket with the Mass air flow sensor/Throttle body. Once you have placed the gasket over the mass air sensor push the front down and make sure up clamps into place, also push down on the sides to to make sure they are clamped down too. Install the front engine cover and you are done. Hope that helps.
