TemjinX2's d2 coil over review
Old 02-16-2009, 02:46 PM
TemjinX2's Avatar
03 g35 coupe...........02 c32 Sold
I bought these for $970 shipped. They offer full 36way damper adjustment and custom springs if wanted. I got them in three days shipped via fedex from taiwan. \
Here are the basic specs
seperate height and preload adjustments allowing for optimal adjustment and allowing full strut travel at all times
6061 high quality aluminum - powder coated for more protection
Threads are teflon coated to prevent rust
Includes 2 keys to adjust ride height
Rebuildable and serviceable in the USA
1 Year Warranty
Specs:
Solid Aluminum Top Mounts: No
Adjustable Top Camber Plate: No
Spring Rate Fronts: 5.2
Spring Rate Rears: 8.5
Part #: D2-B05
i think converted its 291lbs/in in the front and and 476lbs/in in the rear.
I found the spring rates on the Tein SS as comparison
front 336 ft and 448 ft rear.
So there setup for more over steer then the tein's. I decided just to go with the stock spring rates that it came with since i didn't know the c32 spring rates.
Just for future reference, i found this out the hard way, you need to drill out the front sway bar holes to 12mm since they come in 10mm for the other w203's. (thanks splinter for the tip)
So far i'm still fine tunning the damper for daily driving. I have set to 4 notches stiffer from the softest setting to get rid of the bouncyness.
The car rides pretty much like stock...except there's a lot less understeer. If you have 19'' rims it does eat up all the gap. I have the front's at the highest setting and its only a 1 finger gap in the fronts. The rears still have a lot of room for adjustment but i decided to go wit ha 1.5 finger rear.
You do need to reuse your oem bearings, under splinters's advice i decided just to buy new ones since mine looked wore. It also saves a lot of time on the install as well.
If it doesn't rain out this weekend, i'll probably have more at the limit impressions.
Old 02-16-2009, 06:02 PM
c32AMG-DTM's Avatar
2008 A8L, 2002 996TT X50, 2009 X5
Thanks for sharing; sounds intriguing. Any pics of the parts? Your threads usually have 'em...
Old 02-16-2009, 09:28 PM
TemjinX2's Avatar
here's some quick pics i took earlier in the afternoon.
Old 02-16-2009, 09:31 PM
TemjinX2's Avatar
unfortunately i didn't take pics of the coil overs before i installed them. But they were packaged well, i was pretty impressed. I wish my depo tail lights were packaged as well.
this is basically what they look like minus the top mounts.
Old 02-16-2009, 11:38 PM
c32used's Avatar
LET C32 2002
Sweet thanks for sharing
Old 02-16-2009, 11:53 PM
MIDO's Avatar
Location: Home is Stockholm, Sweden. But my work takes me around the world, right now I work/live in Laos, South East Asia.
C32 T 2003. Mods? MANY!! :)
Looks great! Like your ride....
Old 02-17-2009, 05:15 AM
TemjinX2's Avatar
i like your SCAM super charger...lol. I think thats the biggest super charger i ever seen.
Old 02-17-2009, 06:56 AM
MIDO's Avatar
SCAM? You meen SCRAM! Thanks a lot, and yes it is "kind of HUGE" hahaha
Old 02-17-2009, 04:07 PM
greasybenz's Avatar
W203 C32 AMG, W124 E300D
H&R makes sway bars with 12mm holes i believe? So are you using the stock AMG sway bars with this setup?
Old 02-17-2009, 04:21 PM
TemjinX2's Avatar
yeah, i'm using the stock amg sways. I'll probably upgrade later after my pulley maching project. But yeah if it wasn't installed already drilling it out to 12mm wouldn't have taken so much time.
Old 02-17-2009, 08:36 PM
pshek's Avatar
2003 C-Class Sportcoupe
Looks real good Mike. I got to check it out later. Did you get the right tools to install them yourself?
Old 02-17-2009, 09:30 PM
redfarsi's Avatar
04' C32 AMG & 90' TT 300ZX
Man that looks sick. I could use a drop like that. In front there is like a 4 inch gap
Old 02-17-2009, 10:38 PM
TemjinX2's Avatar
yeah i had all the tools already. Only thing i bought was the hat removal tool which i didnt need since i bought another set of oem bearings and couldn't take back, since i bought it on order....
Old 02-17-2009, 11:06 PM
Super Moderator
splinter's Avatar
GMC - Miata - Trek - P-Car
Lookin’ sharp!
Hoping I can hang during our Saturday canyon run.
Old 02-17-2009, 11:31 PM
TemjinX2's Avatar
Originally Posted by splinter
Lookin’ sharp!
yeah i'm hoping the next couple of days it'll stay sunny. i want to test my new coil overs..lol.
Old 02-18-2009, 12:31 AM
MBworld Guru
FrankW's Avatar
white and whiter
looks great mike.
Old 02-18-2009, 06:48 PM
1qikctr's Avatar
Merc power
You got purple etc.... looks nice!
Old 02-18-2009, 06:53 PM
TemjinX2's Avatar
yup Royal Purple..lol.
Old 03-14-2009, 04:38 AM
mdncn2762's Avatar
1992 Toyota Corolla, 1994 Chevy C1500, 2002 C32, 2012 Prius, 2013 Toyota Sienna
Any new updates? Thoughts?
Specs:
Solid Aluminum Top Mounts: No................<did you buy this?
Adjustable Top Camber Plate: No..............<did you buy this?
Part #: D2-B05
Old 03-14-2009, 04:53 AM
TemjinX2's Avatar
after going on some spirited canyon drives..i'm very happy with the performance. Most of the car' stock understeer is gone. I would say at the limit the car tends to oversteer a bit before the traction control comes in. But i prefer oversteer at the limit. You can adjust the damper settings if you want little more oversteer or understeer at the limit.
The only issue had was the driver side coil over where i had to raise all the way to the top just to get that one finger. i didnt have to do it for the passneger side. I believe this is a error on my part on the installation. I think i didnt correctly line up bearing. I plan readjusting it but i've just been lazy. So far it didnt really effect performance at the limit but i does make a clank sound on the driver side but not the passenager side when i drive over deep bumps.
Again my fault on the installation rather then coil over.
I am happy with the quality and packaging it came in coilovers that it came in. At $950 shipped it pretty much gives you tein SS performance with the damper adjustment at a tein basic price.
Old 03-14-2009, 04:56 AM
TemjinX2's Avatar
i would recommend to anyone installing these coil overs to buy the oem bearings separately. Its saves a lot of time from trying to get it off your old stock suspension. My stock bearings were pretty wore anyways, so i'm glad i opted for the new set.
Old 03-14-2009, 04:59 AM
TemjinX2's Avatar
i lowered the front a little more about maybe 1/2 to 1/4 of a finger to get rid of the front gap. the springs are stiff enough so the plastic fender doesn't rub when i go over bumps.
Old 03-14-2009, 05:11 AM
mdncn2762's Avatar
Cool, thanks for the update...
Did you buy these or?????
Old 03-14-2009, 05:21 AM
TemjinX2's Avatar
in other cars...like in hondas and such the d2's come with generic top mounts.
The w203 uses a bearing integrated into the top mount, which looks like a propriety design. Basically you either need to buy a separte set or use your old stock ones and put them over the coil over and it attached to the grooves of the chassis.
i didnt buy the camber plates since i don't really need camber adjustment for the fronts. You dont need them to install the coil over.
i'll try to did up a pic from splinter diy thread.
Old 03-14-2009, 05:26 AM
TemjinX2's Avatar
here's splinters thread
https://mbworld.org/forums/c-class-w...placement.html
Because my W203 has accumulated more than a few miles and its steering felt as if it had lost some of its precision and tracking confidence, it was readily apparent that something was amiss. Since the torque and thrust arm bushing replacements had already been completed, the search was on for the next culprit...sure enough, the source of its numb front end feel, particularly over single-wheel irregularities, was the (#115) strut bearings.
To replace them is an easy and inexpensive task.
Get with your preferred parts purveyor to obtain:
(2) 203 320 02 73 Suspension strut bearing
(2) 203 320 00 56 Strut mounting kit
(2) 203 320 08 44 Rubber buffer
(1) 203 589 00 07 00 Strut retainer tool
The strut R&R procedure has been shared before, so I’ll forego the perfunctory details –
https://mbworld.org/forums/c-class-w203/196922-diy-coilovers-tein.html
The hardware kit is required by MB for any strut installation. It consists of the requisite consumable washers, encapsulated nuts, and bolts with thread adhesive (Loctite) already applied. Is it absolutely necessary? Probably not. Keep in mind that these lowly fasteners are the only pieces holding the strut in place. They are inexpensive insurance against potential separation and the ensuing catastrophic circumstances...
Replacing the rubber buffer (bump stop) and debris shield is optional for OE applications. They are an inexpensive wear item, so their concurrent replacement would be appropriate. Please be aware that the typically stocked 203 320 09 44 is for the increased ride height US (code 486, non-sport) chassis. While they may work well for those encountering tire interference, it will limit otherwise reasonable jounce travel and contribute to understeer. Those of you running coilovers should disregard the MB part number(s) for this phase of the job..
The only challenge to facilitating the bearing replacement is safely compressing the spring. The appropriate tool can be rented or borrowed. My good friend is a Michelin dealer, so I'd arranged in advance to furnish lunch and beverages for his technicians. They had the bearings swapped out pronto! I implore you to always be mindful that compressed springs store a tremendous amount of potentially lethal energy. They will take your head off if it goes awry!
The car felt much more precise going down the road after the installation. It was an investment well spent in that its improvement was immediately apparent. Slowing the aging process and running with the young bucks...LOL!
Quick Reply: TemjinX2's d2 coil over review
