aftermarket fuel pump
Old Feb 16, 2009 | 03:19 PM
redfarsi's Avatar
04' C32 AMG & 90' TT 300ZX
Has anyone used an aftermarket fuel pump or know where I can get one. I found one OEM here for $828 which is definitely better than the $1,200 dealer price.
http://www.parts.com/oemcatalog/inde...layCatalogid=0
Also is the fuel pump Assembly the same thing as the fuel pump? Ir is the assembly just the wiring harness.
Also do you guys think its okay to use an aftermarket fuel pump?
Old Feb 16, 2009 | 06:50 PM
CLKCLK's Avatar
03 C32 gone, 06 CLS55, 16 Tesla X
We use every after market part here lol
LET pulley is after market
Code3 pulley is after market
ECU tune is after market
Brake pad is after market
Tire is after market
want more
SO WHY NOT FUEL PUMP????
But my fuel pump is still good so haven't been looking into it yetLet us know how it goes
Good luck!
Old Feb 16, 2009 | 06:56 PM
SRTpowa's Avatar
Srt-6 Crossfire
240M3SRT on the crossfire forum installed a walbro 255, they usually run around $100 and can support more hp. Not sure if you guys have the same fuel setup as us or not?
Old Feb 16, 2009 | 07:23 PM
pointman's Avatar
a car that can't do the throttle reset.
Redfarsi, you fuel pump gone bad? Can I ask what symptoms you had?
Old Feb 16, 2009 | 09:36 PM
TemjinX2's Avatar
03 g35 coupe...........02 c32 Sold
did they jack up the prices on the fuel pump? the diy in install unversity has it a lot lower.
http://www.installuniversity.com/mb/w203/w203/fp.html
Old Feb 16, 2009 | 10:56 PM
c32used's Avatar
LET C32 2002
how you know your fuel pump is bad?
Old Feb 16, 2009 | 10:57 PM
redfarsi's Avatar
pointmam: The car doesn't start. Crank sensor is good. Fuel Pump relay burnt itself my service rep, a real nice guy, gave me a new one for free we put it in car almost started, sounded like it ran for a second and died. We tried again and nothing. Battery and alternator are good. He said they checked my motor and everything is good on the car, except the pump.
TemjinX2: that pump from installuniversity is for s c240. c32 uses a stronger fuel pump that runs are higher pressure(?). Its two diff pumps. normal w203 pump is like $300, and a w203 amg pump is like $900
c32used: I took it to the dealer and they did a full inspection for $125. Hooked up to star(i think). My service rep told me they checked all the components and their tech ran power straight to my pump and there was no go. They are 100% sure its my pump or so they claim.
Old Feb 16, 2009 | 10:58 PM
c32used's Avatar
LET C32 2002
Thumbs up
for the link
Old Feb 16, 2009 | 11:29 PM
pointman's Avatar
Interesting. I am curious cause I hear several taps from the backend when I stop at a red light. I am almost positive its the pump, but not sure if its normal or not.
Old Feb 17, 2009 | 12:13 AM
redfarsi's Avatar
I am thinking about getting a walbro 255 but I'm not sure if it will be compatible. Anyone can chime in on this?
Old Feb 18, 2009 | 07:56 PM
redfarsi's Avatar
walbro doesn't make a fuel pump for c32
Old Feb 20, 2009 | 12:17 AM
70GS455's Avatar
1970 Buick GS 455
There is a thread on the XF forum discussing pumps:
http://www.crossfireforum.org/forum/...ad.php?t=32034
HTH
Old Feb 20, 2009 | 12:28 AM
70GS455's Avatar
1970 Buick GS 455
Ooops. Just realized, the C32 pump is in-tank, the SLK pump is external like the SRT. So nevermind the above.
Old Feb 21, 2009 | 03:15 AM
pshek's Avatar
2003 C-Class Sportcoupe
Has anybody with a tuned C32 tried using a Boost A Pump? Quite a few people with supercharger kits use these....
