Needswings SuperCooler
Old Feb 24, 2009 | 09:09 PM
Gramma_Benz's Avatar
2002 C32, 2012 S550
Wow, there's some pretty cool stuff going on over in the Crossfire Forum.(no pun intended)
Including some manifolds in testing to gain 40% more airflow?
Hope some of this stuff will fit on our cars too....
http://www.crossfireforum.org/forum/showthread.php?t=32137
And for those of you you cannot see the photos:
Attached Thumbnails Needswings SuperCooler-needswings-he.jpg   Needswings SuperCooler-needswings-he2.jpg   Needswings SuperCooler-needswings-he3.jpg
Old Feb 24, 2009 | 09:28 PM
OverDrive's Avatar
Volvo
If these were for the c32.... i would be pretty upset since i just went out a bought a new radiator.
Old Feb 24, 2009 | 10:27 PM
SilverBulletAMG's Avatar
C32 AMG
Is it a giant heat exchanger? Looks like it goes in front of the radiator?
Old Feb 24, 2009 | 10:37 PM
ImportLabSRT's Avatar
2006 E55 2005 Crossfire SRT-6
Wow... those pictures look really familiar....lol. If anyone has questions about the Needswings Heat Exchanger, let me know.
Old Feb 24, 2009 | 10:42 PM
C32 AMG
Will these fit the 32?
Old Feb 24, 2009 | 11:06 PM
Im going to say no.... it barely fits the SRT-6. Its really snug between the hood latch and a/c condenser. Ill see if Jake or Andy will let me take some measurements on one of their cars sometime.
Old Feb 24, 2009 | 11:17 PM
c32used's Avatar
LET C32 2002
Old Feb 24, 2009 | 11:30 PM
cruzinquick's Avatar
2005 Crossfire SRT6
Post up in the E55 section so Jangy can check it out. Rob will have an E55 in there soon to verify it fits in there as well.
Old Feb 25, 2009 | 08:05 AM
c32AMG-DTM's Avatar
2008 A8L, 2002 996TT X50, 2009 X5
Is this the same, or different, from the one Woody made from a Summit Racing radiator? IIRC, he was collaborating on some NW projects...
Old Feb 25, 2009 | 08:14 AM
Its a Woody design.... Rob and Woody have been working in conjunction on this and a few other things soon to follow. This is basically a reworked radiator with relocated inlet and outlet. The only thing I do not like about it is that it covers the whole A/C condenser and Radiator. I may look at adding a slim pusher fan to the outside to aid in cooling of the radiator.
~edit~ Or better yet, wire in a relay to the I/C pump and run a slim fan off of that on the front side of the cooler.
Old Feb 25, 2009 | 04:20 PM
amgstyle's Avatar
2002 SLK 32 AMG
is this supercooler suppose to replace the radiator or the i/c heat exchanger?
Old Feb 25, 2009 | 04:29 PM
C32 AMG
I wondered the same thing at first glance. It replaces the heat exchanger though and sits in front of the radiator.
Old Feb 25, 2009 | 06:08 PM
msheredy's Avatar
MB
It replaces the heat exchanger.
Note that every intercooler heat exchanger and front mounted air to air intercooler are always mounted before the radiator. Radiators are thermostatically controlled so the water sits in the radiator for a while. Heat exchangers aren't so they need to coolest air possible to work effectively.
Old Feb 25, 2009 | 07:39 PM
TemjinX2's Avatar
03 g35 coupe...........02 c32 Sold
too bad i already installed my behr radiator already.
Old Feb 25, 2009 | 08:08 PM
c32AMG-DTM's Avatar
This doesn't replace the radiator... it replaces the HE (i.e instead of a Code 3 or LET type HE). This one allegedly holds more, flows more, and cools better - that said, it's probably a non-issue for C32's anyway - I doubt it would fit. Good option for the SLK-32 and SRT-6 folks, however.
Old Feb 25, 2009 | 09:55 PM
TemjinX2's Avatar
ic..thought it was a radiator from the pics..oh well i already upgraded my heat exchange and radiator already anyways.
Old Feb 25, 2009 | 11:26 PM
c32AMG-DTM's Avatar
Old Feb 26, 2009 | 10:47 AM
loungn14's Avatar
SPONSOR
From: Houston/ Austin /Toronto / UAE / Minneapolis / Orlando /Cincinnati
Eurocharged Performance ML63 and TT lambo
seems like wayyy overkill.
Old Feb 26, 2009 | 11:08 AM
C32 AMG
You say that like it's a bad thing.lol
Old Feb 26, 2009 | 11:10 AM
MRAMG1's Avatar
S600, GL450, GLC 43
+1
I had the code3 He and even after a 30 minute road couse session I had NO heat soak issues. And that was with a pulley guys. Oh well, maybe they are running 30 pounds of boost
See yeah
Old Feb 26, 2009 | 03:14 PM
loungn14's Avatar
SPONSOR
heat exchanger and seperate the cooling system and no need for big *** radiator...
just my 2 cents...
Old Feb 26, 2009 | 03:59 PM
MRAMG1's Avatar
S600, GL450, GLC 43
just my 2 cents...
Don't forget about that much MORE weight, in the LAST place that you want/need it.
See yeah
Old Feb 26, 2009 | 09:26 PM
c32AMG-DTM's Avatar
Woody's (waldig) prose is, well, a little... different - that said, he definitely knows his stuff, and tests mods scientifically to the "nth" degree. If anyone cares to read more about these, follow the links:
http://www.crossfireforum.org/forum/...ad.php?t=28137
http://www.crossfireforum.org/forum/...ad.php?t=28904
As I mentioned earlier - probably a non-issue for C32's anyway... I doubt it would fit our chassis configuration.
Old Feb 26, 2009 | 11:47 PM
just my 2 cents...
I have both
Old Feb 27, 2009 | 08:00 AM
C32 AMG
just my 2 cents...
What do you mean by seperate the cooling system?
