HELP! CAR WON'T START!
Old Mar 3, 2009 | 09:48 PM
jturkel's Avatar
02 C32 AMG
Drove to school this morning, car started up fine, no problems. Car sat in parking spot for 8 hours and now I have a problem.
My car IS turning over BUT it will NOT START.
I tried multiple times with two difference keys, but to to no avail.
I have had no problems or forewarnings about this. There have been no CELs. Car has been starting fine. I already had my seat modules replaced, but even if i hadnt, the car is turning over so that isnt the problem. The A/C menu thing reads 12.0V when I search that.
What is the problem?
Just did a search of a lot of threads.........
All I can find is a bad Crank Positioning Sensor? Not sure if unplugging the battery will do anything or not.
Anything else? Suggestions....i hate this....and i have a test tomorrow.
Old Mar 3, 2009 | 09:53 PM
TemjinX2's Avatar
03 g35 coupe...........02 c32 Sold
my best guess was cps too..hope it works out man. maybe spark plugs?
Old Mar 3, 2009 | 09:54 PM
jturkel's Avatar
02 C32 AMG
spark plugs havent been replaced yet. 79K. i am in AZ, but it isnt running that high of boost. hmm...
i was reading about SAM....what is that? and something about fuses 48 and 46?
Old Mar 3, 2009 | 10:06 PM
Vadim @ FD's Avatar
S600TT, R350
Josh, check fuel pump fuse. I believe it is number 5 in rear SAM..
Your headers are on the way.
Thank you for your order.
Old Mar 3, 2009 | 10:12 PM
jturkel's Avatar
02 C32 AMG
where is rear SAM? any diagram of this?
Old Mar 3, 2009 | 10:21 PM
DarkXerox's Avatar
07 E550, 02 C32, 91 300E
How old is your battery? I think we went over this before.
Old Mar 3, 2009 | 10:26 PM
jturkel's Avatar
02 C32 AMG
ive had battery replaced three times due to two bad seat modules. battery is NOT old and is not the problem. the engine is turning over, so it is not a battery issue. it is either fuel or spark related....or crank positioning sensor i think.
Old Mar 3, 2009 | 10:45 PM
jturkel's Avatar
02 C32 AMG
anyone other ideas or suggestions?
Old Mar 3, 2009 | 11:34 PM
alkrstev's Avatar
Silver 02 C32 & White 05 CLK500
I know you said that it is not the battery, but I had the same problem when my seat module went out. It drained the battery, and while the car was cranking, it would definitely not start. Try the jumper cables and see if it starts back up. Good luck, I hate how so many things go wrong with these cars.
Old Mar 3, 2009 | 11:37 PM
1qikctr's Avatar
Merc power
It can be ur fuse or TPS. Check ur fuse first.
Old Mar 3, 2009 | 11:47 PM
Vadim @ FD's Avatar
S600TT, R350
In the trunk on the left side, there is a 7''x2'' fuse cover. If you remove it, I belivee fuse number 4 or 5 - 15 amp is the fuel pump. I have seen them blow on C32s and C55s.
Good Luck!
Old Mar 4, 2009 | 12:17 AM
jturkel's Avatar
02 C32 AMG
well car started and now i'm back home. not sure what the problem was.
went back and pulled checked out fuses 4 and 5. 4 is fuel pump and 5 is water pump. nothing wrong, put them back in. then did a little spark test and there was spark.
and then the car magically started.....awesome....no idea what it was
Old Mar 4, 2009 | 12:18 AM
alchang32's Avatar
C32 AMG
prob the crank position sensor.
Mine went out a while back. got it replaced. its cheap fix.
Old Mar 4, 2009 | 12:24 AM
jturkel's Avatar
02 C32 AMG
where did you get it? did you DIY? price? is the CPS the only part that needs to be replaced if that it the case or are there other parts as well?
Old Mar 4, 2009 | 12:26 AM
boohooramblers's Avatar
Not an AMG :(
Good news! Although, unfortunately it's probably likely it'll occur again.
I think Vadim's on the right track with the fuel system.
If you have an OBDII scanner, scan your system and see if you come up with any P201 codes (especially 201B and 201C). These would indicate that the fuel gauge reading is incorrect.
Other things to consider pertaining to the fuel delivery system (these are known to cause issues from time to time):
A. Fuel pump relay (N10/2kA in the rear SAM).
B. Overflow valve on the fuel pump.
C. Fuel level sensors (left and right; B4/1 and B4/2, respectively).
D. Fuel tank pressure sensor (B4/3).
Let me know if you need diagrams for them.
Old Mar 4, 2009 | 12:28 AM
jturkel's Avatar
02 C32 AMG
thanks for the input! if(hopefully not when) it happens again, i will 99.9% sure ask you if you could get me diagrams. thanks!
Old Mar 4, 2009 | 12:35 AM
denice25's Avatar
civic
Please check your spark plugs, alternator and battery!!!
Old Mar 4, 2009 | 12:41 AM
c32used's Avatar
LET C32 2002
Sorr Bro for your car issues hopefully it will end soon.
Old Mar 4, 2009 | 12:42 AM
jturkel's Avatar
02 C32 AMG
checked for spark and it was present....spark plugs and wires being replaced this weekend anyway
battery is fine....like i said, reads 12.0V and the car turned over
alternator definitely not the issue
if the car turns over but it doesnt start, it is either a fuel issue, spark issue, or a possible CPS issue (so i have read and have been told)
Old Mar 4, 2009 | 01:20 AM
alchang32's Avatar
C32 AMG
i had a local tech to fixed it for me...the part it self cost less than $50 bucks.
Old Mar 4, 2009 | 04:24 AM
TemjinX2's Avatar
yeah buy the cps sensor on ebay for $50...replacing it is a pain. I sitll havent gotten around to it.
Old Mar 4, 2009 | 04:42 AM
jturkel's Avatar
02 C32 AMG
maybe i'll do it anyway. after all, i will be doing a huge installation project probably this weekend: plugs, wires, headers, and LET 185 kit (hopefully)
Old Mar 4, 2009 | 08:10 AM
ImportLabSRT's Avatar
2006 E55 2005 Crossfire SRT-6
Your supposed to reset the flywheel adaptations when you install a new CPS.... but you dont have to. The car will eventually learn. Have you had hard starting before? Or extended cranking before? If the fuel rail sees no pressure from the fuel pump, the start usually will disengage. If the CPS is shorted, the starter will continuously run until the key is turned off or 15sec IIRC. And if the CPS has an open, the starter will engage and disengage at times instantly. Hope that helps a little.
Old Mar 4, 2009 | 11:28 AM
jturkel's Avatar
02 C32 AMG
nope. no problems before and no unusual starting.
just last night, it wouldnt start. i would try to turn it on and you hear it turning over but it just would not turn on.
....what do you mean by "if the CPS has an open" ?
Old Mar 4, 2009 | 11:54 PM
Donmun's Avatar
2002 S500
how many miles do u have on ur car, if it about 80K the most likely suspect is the CPS (mine went bad at 80K miles). if it has 115K or so replace the fuel pump relay ( mine went bad about 3 weeks ago but gave me some warning, it would take longer to start sometimes, i had a post on it. ur fuel pump relay is in the third slot from the bottom in the trunk fuse box (u may not have anything in the 2nd slot)). if it happens again pull the relay out and use a wire to jump the relay (i dont remember the pin numbers but if u look at the side of the relay u should see the diagram). the relays cost about $20 but be prepared to explain to the dealer where exactly it fits in the car because mine did not have a clue what i was talking about.
I hope this helps
Donahue
