Things in the mix: it never ends
I know the C32 and E55 guys have have been using the Johnson pump with relatively good results. So after some quick research I went to a local boat shop and bought a killer bilge pump that can flow like crazy (If i wanted it to). I think its a Jabsco pump I cant remember. I will be having that installed on my car tomorrow and it will have some control valves set up under the hood so flow rates can be controlled.
All I can remember is the pump is shaft driven and has a flexible impeller, Not magnetically driven like other pumps. When we do some data logging we will be able to adjust the pump to flow for the best IAT (kinda cool).
Also I'm going to be retro-fitting a set of SL65 brakes and rotors to my car. Couldn't pass up the price.
We also will be mounting some small fans on the H/E for some extra cooling.
We are still working out a bug with the throttle body, but the shop is going to come up with a solution.
Lastly: and this may pain some of you, but we going to install a blow-off valve. I will do my best to lobby for a spot that is out of view
if the pump flows too much, wont it get backed up at the intercooler? i thought i remember reading that somewhere for the c32s. if c32s apparently have an upgraded pump and a larger H/E, i thought i read it gets backed up at the I/C (becomes the rate limiting step)
and please discuss the fans on the heat exchanger in depth when it gets installed. i need as much cooling as possible in this AZ heat and need some serious cooling mods like that and like your awesome little coolant pump/reservoir/thing that runs and cools down your s/c when the key is in the accessory position
As for the pump, who's to say 3 times more flow will give you the best benefit? what if you need 2 time the flow to get to the bet IAT? or maybe you need 4 or 3.5 times to really keep your IATs in a safe spot.
other F/I car people spend lots of cash on pump combos to try and cool their cars down. So why cant you buy a pump that flows alot more than a johnson mc30 but have the ability to reduce or increase flow to meet your demands?
believe it or not there are parts for your car at your local boat shop.
I will do some data logging tomorrow with the old bump and the new pump, If the idea fails than o well.
im still down for fan setup on the h/e and your pump that runs with just the key in.
Josh - fans on the OEM HE has been done by the SRT-6 folks... pretty sure there's some good info on it over at their forum. It was discussed adding ones to an upgraded HE, but never done to my knowledge - not enough room (IIRC). And yep, flow will "back-up" in the cooling system wherever the major point of restriction is... likely the IC in ours, once other areas have been upgraded.
yah, there is minimal space there. fan has to come out to get an impact wrench to take off the crank pulley. major PITA. i dont think there is enough space. Mike has an awesome pump/reservoir/thing that cools down his S/C when the key is in the accessory position. It does not necessarily increase coolant capacity nearly as much as the Code3 (1.2 gallons), but it constantly runs and can run while your car is in line at the track to keep the temps down. Maybe Mike will be nice enough (if he has time) to post up some info or a vid about it. i may go over to dynocomp and have them retrofit my car with one like they did his (though i really want to increase fluid capacity too).
I'm watching this one with interest. And a BOV?lol
bov is figured-you're running the sc hardwired with no clutch disengagment-you need the pressure to go somewhere (recirc the air past the MAF sensor-VTA will require a whole other tune to compensate for the air the MAF has read-but is not getting to the cyl).
gl on the conversions-I can tell you from experiance-ones this starts-it wont end-
hows the tranny hold up to all this? I see you commented on the axels-but I have to believe at some point the tranny will not like the new powa!
You're right though...never really thought about it.
As for the fans I bring up the idea of weiring them into the radiator fan so when that kicks on the H/E fan does too. And its true you will never find a fan that would work at speed.
You are correct.
The reason our front-mount heat exchanger isn't an intercooler, is that the intercooler is the piece of hardware that directly cools down the intake charge in a F/I application. As mentioned above, ours sits in the valley of the engine's "v" underneath the S/C. The heat-exchanger is the intercooler's "radiator" - cooling down the fluid in the air-to-water setup to boost the thermal efficiency of the system. No intake charge air passes through the FMHE; consequently in no way is it an intercooler. Hope I'm explaining it well...
Hooley.lol
Fans on your intercooler circuit should help a lot by the way. The front mount spray kits do not really do anything on air/water setups though. It takes too much to cool down the water in the system. The best way to get really cold water is a separate reservoir with ice in it. Move your battery to the trunk and build a reservoir there. This is what I did and it works great.
