Eibach c32 front sway on c55?
Old Apr 21, 2009 | 07:34 PM
spr's Avatar
spr
So I seem to be having some problems mounting the c32 eibach bar on the front of my c55. Has anone done this or can provide some insight??? Thanks. Sean
Old Apr 21, 2009 | 07:39 PM
Zeppelin's Avatar
C32
What's the problem? If the hole sizes where the endlinks mount are too small then you just need to drill them out. This would mean the bar is not C32 specific.
Old Apr 21, 2009 | 07:42 PM
spr's Avatar
spr
The end link holes are not the issue. They've been drilled to 12mm. The bar will not mount to the chassis as it is a w209 front end with different mounts.
Old Apr 22, 2009 | 02:13 PM
rockjock's Avatar
I DON'T COME HERE ANYMORE
need diff mounts-MB has a narrow and wide mount for the bushings (had to swap to wide for mine with H+R to fit)-they didnt come with new ones?
Old Apr 22, 2009 | 07:42 PM
spr's Avatar
spr
Thanks. I know they came with different mounting hardware but was unable to inspect either as it all went to the shop, and both of my shops told me it will not mount as such.
Old Apr 22, 2009 | 08:50 PM
jayton41's Avatar
05 C55 & 06 C230 SS
y did u get eibach when h&r had one specifically for the c55
Old Apr 22, 2009 | 08:54 PM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
mounting bracket under the car should be the same as the 32. suspension components other than tuning wasn't different from the 32. I used the bushing from Eibach and used the stock bracket. it may seem like it doesn't fit until you bolt on the screws.
lots of mechanic would tell you they don't fit simply because they're too lazy to even try.
Old Apr 22, 2009 | 09:42 PM
spr's Avatar
spr
Because the rear is significantly larger
Old Apr 22, 2009 | 09:57 PM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
yea, I just used the eibach bushing and the stock bracket and it worked fine.
Old Apr 23, 2009 | 07:33 PM
spr's Avatar
spr
What my mechanic was saying was the the mount was wider than the swaybar or vice versa.
Old Apr 23, 2009 | 07:41 PM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
the bar plus the bushing will look much bigger compare to the old bar and bushing while the bracket remain the same size, but it will still mount on. I did my front and rear DIY with help of a friend.
Old Apr 23, 2009 | 07:46 PM
spr's Avatar
spr
Are you sure this is the case, as it seems you have a c32 with a 203 front end whereas my c55 has a 209 front end and is different. Do you have personal knowledge that this is the case on a 209 front end? Thanks. Sean
Old Apr 23, 2009 | 07:48 PM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
32 and 55 front end only different in sheet metal. the under pin in the suspension are all the same.
Old Apr 23, 2009 | 07:51 PM
spr's Avatar
spr
Ok. I'll check it out. I've yet to look at anything, just had the two shops trying to mount it up.
Old May 8, 2009 | 12:04 AM
spr's Avatar
spr
Ok. So I did the research and found out that the older w203's have the wider sway bracket whereas 05+ have the narrow. I've picked up a set of the wider ones and they slip on the bushing just fine. However, what is the relation to the notch on the bar and which way do the mounts face, e.g. which way faces out? Anyone have pics of them on the bar or the bushings used with them? Thanks I have yet to throw it on the lift, but want all the info now if I need to buy other bushings etc. Thanks. Sean
Old May 9, 2009 | 06:10 PM
mb_c55amg_guy's Avatar
2005 c55amg, 2000 clk430, 2002 clk55amg, 2008 clk63amg black series
need some info also...
H&R sells 2 types of sway bars for the c55, both bar diameters are 26 and adjustable, however one has 10mm end link holes while the other has 12mm end link holes. Which one should i buy?
Old May 9, 2009 | 09:26 PM
spr's Avatar
spr
12mm for c55 front. Does anyone know if eibach makes a rear adjustable? Evidently mine is not.
Old May 9, 2009 | 09:37 PM
thanks
Old May 9, 2009 | 09:45 PM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
rear's not adjustable.
Old May 10, 2009 | 07:28 PM
spr's Avatar
spr
Ok. So we now have a conclusion. The c32 eibach bar will NOT fit on a c55 as both of my mechanics confirmed previously. Sure you can mount it up but it will have 1/2" slack on both ends causing the bar to move latterally and not work worth sh*t. I tried it with both sway mounts older pre05 and my stocks. BS. Bar is going and getting H&R. The front end of the c55 AS A 209 HAS DIFFERENT MOUNTING POINTS FOR THE SWAY.
Old May 10, 2009 | 08:34 PM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
pics? did you put the bars side by side and compare?
Old May 11, 2009 | 01:17 PM
spr's Avatar
spr
I did. The notch is in a different place on the bars - where the center of the bracket should be etc. I didn't take pics as I was over it. They simply don't work on a c55. Eibach confirmed. Going H&R front.
