Question: Removing Secondary Cats (possible issues)
I was talking to a friend of mine, who worked for MB & is extremely knowledgeable, and he told me it may not be a good idea. He said that the computer would think the engine was running cold and in turn I would run lean and possible throw a check engine light.
To my knowledge there are only sensors on the primary cats so I’m unsure how it would run any differently with the secondary removed and the mufflers gutted. I would only expect a slight increase in flow and hopefully a noticeable increase in sound (main reason for even doing anything)
Input anyone?
Input anyone?
Better sound, lose 20 lbs (res and secondaries), better performance, no smog issues. The only downside is the cost of removal, IMO.
C32s have definitely removed the secondary cats before. however, you will not see sizable gains like Hooleyboy did. You will have a slightly louder exhaust sound, will drop a little bit of weight, and will have a little better flowing exhaust. maybe a gain of 1-2whp, like with the resonator delete. however, if you ever did headers, deleting the resonator and secondary cats will net you more gains with the headers than if you had the resonator and secondary cats b/c these are no longer bottlenecks in the exhaust.
Cool, thanks brother. Hope you're feeling better.
hope that helps.
AMS
