Highly recommend - Devtoaster REV + WLAN ODB2 Monitor
Old May 5, 2009 | 02:12 PM
alumar's Avatar
2019 E63s AMG
Heya guys,
For the past few days I have been playing around with this toy i picked up that interacts with my Apple Iphone.
From the apps store, you can purchase REV for 29.99 ... and link it up to one of many wireless ODB2 devices that can be viewed @ their website.
http://www.devtoaster.com/products/rev/index.html
You can record multiple real time readings and have the results sent to you in email through your iphone via a .csv file (excel)
Per example... I attempted a 0-60 run... here was the results:
MPH - TIME
0 6:15:18 AM
8.07 6:15:18 AM
11.18 6:15:19 AM
20.50 6:15:19 PM
32.31 6:15:20 PM
41.01 6:15:21 PM
48.46 6:15:21 PM
55.92 6:15:21 PM
63.37 6:15:22 PM
roughly low 4 sec to 63mph...
Here is another detailed view of that run (i actually went to 106mph)
The numbers are listed in order: Time, MPH,MAF,Throttle Position
6:15:18 PM 0.00 3.69 1.18
6:15:18 PM 8.08 72.88 70.59
6:15:19 AM 11.18 98.47 13.73
6:15:19 PM 20.51 163.11 100.00
6:15:20 PM 32.31 218.58 99.61
6:15:21 PM 41.01 269.91 100.00
6:15:21 PM 48.47 221.86 100.00
6:15:21 PM 55.92 228.91 99.61
6:15:22 PM 63.38 251.50 99.61
6:15:23 PM 68.35 273.61 100.00
6:15:24 PM 73.32 229.91 48.63
6:15:25 PM 78.29 211.05 100.00
6:15:26 PM 82.02 216.33 99.22
6:15:26 PM 86.37 227.94 100.00
6:15:27 PM 90.72 238.80 100.00
6:15:28 PM 95.07 250.80 100.00
6:15:28 PM 99.42 260.72 99.61
6:15:29 PM 103.15 266.80 100.00
6:15:29 PM 106.88 274.88 100.00
0-106.88mph in roughly 11.00 seconds
A few points I have noticed using the device... while I was running up to 100 around 2nd to 3rd there is a hesitation (slight) when the car is shifting, ...actually its not the smoothest shift, kinda rough actually... but this data is showing my throttle position drops to nearly 50% even though i have my foot planted.
Countless other features including the ability to show vehicle CEL codes, reset them and monitor pending issues.
I will be making a short little video showing how it works later... i know you guys will like it.
Old May 5, 2009 | 02:42 PM
TopGun32's Avatar
can you monitor IAT's and timing?
this is a great product if so.
Old May 5, 2009 | 02:43 PM
TopGun32's Avatar
never mind.. it does ..
wow!!
i think i just found my new phone and app
Old May 5, 2009 | 02:45 PM
alumar's Avatar
2019 E63s AMG
Yes... it does
Old May 5, 2009 | 02:57 PM
TopGun32's Avatar
which OBD2 connector did you use?
Old May 5, 2009 | 03:00 PM
alumar's Avatar
2019 E63s AMG
ElmCanII-WLAN - i ordered from the link on the site. It comes from Germany... took about 7 days to Midwest.
The program and ElmCanII-WLAN works on any car... I have tested with various friend's cars... even one of them that had a check engine line (had it on for years and never looked into it)... ended up being some vacum pressure issue with leaving his gascap off one day.. i reset it and it hasnt came back on ! ... ha ha
Old May 5, 2009 | 03:41 PM
alumar's Avatar
2019 E63s AMG
Got some great info from Cory
Actually, that's not strange at all. These cars close the throttle between shifts, as not to shock-load the transmission- a protection feature built into the ECU and TCU. With the torque your car is making, it would break something were the throttle to remain open 100% while it's shifting- shock loads are a transmissions worst enemy. :-) This is probably the #1 complaint I get, even on stock cars- most just hate they way these cars are programmed to shift, and I tend to agree. If only the old cars got the double-clutch 7-Speed that's in the SL63....
Those are nice times! almost as fast as Car and Driver got our demo C55 to go, but then again, they were using very expensive VBOX GPS based measuring instruments which are likely more accurate than the REV app for the iPhone. I think the fastest they got our old demo car to go was like 3.8 0-60. I've seen other customer C55's run 11.75's in the 1/4 on street tires before....Get a set of DR's and get those low 11's posted
Cory Umemoto
Technical Manager
Old May 5, 2009 | 04:27 PM
Gramma_Benz's Avatar
2002 C32, 2012 S550
Awsome, thanks for the heads up!
BTW, when I look up the app the price displays $39.99.
Still much cheaper than any other logging-scanner though.
Old May 5, 2009 | 04:48 PM
alumar's Avatar
2019 E63s AMG
ah musta been a weekly special when i ordered on appstore ..
additional non-topic info from cory (anyone ever try this?)
At the drag strip, I'd recommend keeping the car on (not running, but key in the on position) and turning the heater up to max hot/max fan speed while you're waiting to stage- this will help get heat out of the motor significantly faster than just letting it sit with the hood open- this is what I do when I have a car on the dyno- I actually keep the heater on at all times- it makes a pretty big difference in terms of delaying heat soak, and recovering from it much, much faster.
Old May 5, 2009 | 06:28 PM
c32AMG-DTM's Avatar
2008 A8L, 2002 996TT X50, 2009 X5
Yup - he's right, too... works like a charm, especially if you're at the track on a cool night.
Old May 5, 2009 | 11:10 PM
c32used's Avatar
LET C32 2002
Question
I just downloaded Rev lite for free but you stated I needed access to OBDII right can you post a link for that item?
Old May 5, 2009 | 11:18 PM
c32used's Avatar
LET C32 2002
Exclamation
Actually I found it but damn very expensive device
Old May 5, 2009 | 11:24 PM
2002 C32, 2012 S550
WHOA! Yeah, I just now saw that the connectors or wifi to interface with the iPhone are all over $200.
Old May 5, 2009 | 11:29 PM
c32used's Avatar
LET C32 2002
I love this idea but that expense is pushing me to a $99 data logger instead.
Old May 5, 2009 | 11:38 PM
c32used's Avatar
LET C32 2002
Question
Would any of these work?
http://www.laplogger.com/
Old May 5, 2009 | 11:41 PM
c32used's Avatar
LET C32 2002
IDK maybe this is my route...
http://www.midwayautosupply.com/show...iliateid=10050
Old May 5, 2009 | 11:44 PM
c32used's Avatar
LET C32 2002
Interesting also...
http://www.auterraweb.com/
and this
http://tunertools.com/proddetail.asp?prod=IN-3790
and this
http://www.microdaq.com/davis/automo...hip_logger.php
Old May 5, 2009 | 11:52 PM
alumar's Avatar
2019 E63s AMG
ya the wifi odb2 is about 270.00 after shipping ; guess that is kinda expensive ... The thing to consider though is this is "not" just limited to your car... this can be used in any car... your DD, friends car, parents, rentals ... whatever has 4 wheels and ODB2
minimal expense to have as a fallback device imo since it pulls codes, allows you to clear and has various other features
Old May 6, 2009 | 01:39 AM
alumar's Avatar
2019 E63s AMG
up a slight hill very flat up top
Time- Throttle Position- Vehicle Speed- Forward Acceleration- Lateral Acceleration- RPM
9:49:13 PM 17.25 55.92 0.1967 -0.0733 2170
9:49:14 PM 99.61 57.79 0.2518 -0.0259 4137
9:49:14 PM 100.00 63.38 0.3973 -0.0781 5918
9:49:15 PM 100.00 68.97 0.5440 -0.0032 6463
9:49:16 PM 50.98 75.19 0.4863 -0.0627 5260
9:49:17 PM 99.61 78.91 0.4434 -0.0453 4702
9:49:17 PM 100.00 83.26 0.4697 -0.0959 4993
9:49:18 PM 100.00 87.61 0.4346 -0.0787 5202
9:49:19 PM 100.00 91.34 0.4596 -0.1045 5431
9:49:19 PM 100.00 95.69 0.4207 -0.0521 5678
9:49:20 PM 99.61 99.42 0.4537 -0.0976 5886
9:49:21 PM 99.22 103.15 0.4269 -0.1552 6111
9:49:21 PM 100.00 106.88 0.4258 -0.1519 6325
9:49:22 PM 100.00 109.36 0.4248 -0.1607 6353
9:49:23 PM 92.16 111.85 0.3689 -0.1517 4807
9:49:23 PM 100.00 114.33 0.3611 -0.1775 4817
9:49:24 PM 100.00 116.82 0.4475 -0.1303 4916
9:49:25 PM 100.00 119.30 0.3649 -0.0984 5014
9:49:25 PM 100.00 121.17 0.3088 -0.0348 5135
9:49:26 PM 99.61 123.65 0.3190 -0.0511 5201
9:49:27 PM 100.00 125.52 0.3579 -0.0882 5298
9:49:28 PM 100.00 128.00 0.2699 -0.0797 5403
9:49:28 PM 100.00 130.49 0.3524 -0.0038 5506
9:49:29 PM 100.00 132.97 0.3410 -0.0226 5610
9:49:29 PM 100.00 134.84 0.3432 0.0132 5680
9:49:30 PM 100.00 137.94 0.3104 -0.0176 5758
9:49:31 PM 99.61 139.19 0.2782 -0.0333 5857
9:49:32 PM 99.61 141.67 0.2939 -0.0701 5946
9:49:32 PM 28.24 138.57 0.1754 -0.0486 5783
9:49:33 PM 9.80 136.08 0.0222 -0.0968 5471
9:49:35 PM 10.20 132.35 -0.0538 -0.1468 4962
9:49:35 PM 8.63 118.06 -0.2480 -0.1003 4094
9:49:36 PM 8.24 113.71 -0.1531 -0.3169 3938
9:49:37 PM 8.24 110.60 -0.1418 -0.2048 3835
9:49:37 PM 7.84 106.25 -0.0484 -0.1209 3698
9:49:38 PM 7.84 100.66 -0.1899 -0.1893 3467
9:49:39 PM 7.45 93.21 -0.2547 -0.2041 3233
9:49:39 PM 7.06 88.23 -0.1303 -0.2014 3060
9:49:40 PM 7.45 85.75 -0.0912 -0.1398 3409
9:49:41 PM 7.84 83.89 0.0536 -0.2177 3509
9:49:41 PM 7.84 82.64 0.0737 -0.1814 3445
9:49:42 PM 7.45 82.02 0.0817 -0.1714 3386
Old May 6, 2009 | 01:46 AM
alumar's Avatar
2019 E63s AMG
man i was just thinking..slap some gps coordinates on this and the po po have everything they need to give someone a ride in the back seat; interesting.. luckly this was on a closed track
Old May 6, 2009 | 01:24 PM
TopGun32's Avatar
I would also look into the blue tooth connector instead of the Wifi.. probably cheaper.
either way.. i'll wait until the connectors are cheaper.. and BlackBerry has an app similar to the Iphone.
those of you that are programmers.. there is $$ to be made.
Old May 6, 2009 | 02:08 PM
alumar's Avatar
2019 E63s AMG
ya if you think about it... simple wifi usb with a hardcoded ad hoc AP connection setup, then just transmit the ODB2 info
they are making a killing at 260 each
Old May 6, 2009 | 02:51 PM
c32used's Avatar
LET C32 2002
please keep us in the loop if you find one!!
Old May 6, 2009 | 04:38 PM
TemjinX2's Avatar
03 g35 coupe...........02 c32 Sold
yeah its a great app...i plan on doing something similar with my car puter.
http://vimeo.com/3565136
Old May 6, 2009 | 09:50 PM
TopGun32's Avatar
http://www.obdkey.com/obd_orders.asp
this company has 3 types... 1st one is Bluetooth and cheaper.
You have already rated this thread Rating: Thread Rating: 2 votes, 5.00 average.
