Boost gauge position?
Old Jun 8, 2009 | 06:19 PM
Robert AMG's Avatar
Cls63 & C32
Where is the best place to install a boost gauge?
Is it the same boost before and after the supercharger?
Thanks.
Old Jun 8, 2009 | 07:47 PM
SilverBulletAMG's Avatar
C32 AMG
Good question. That and a good data logger are on my must have list. There are just so many choices out there! What boost gauge did you end up with?
Old Jun 8, 2009 | 09:41 PM
jturkel's Avatar
02 C32 AMG
tap the y-pipe
Old Jun 8, 2009 | 11:18 PM
Lenin's Avatar
2002 C32 AMG, 2013 GLK 350/4, 2015 E63S AMG Wagon
Originally Posted by jturkel
tap the y-pipe
+1. It's the safest and easiest place IMHO.
Old Jun 9, 2009 | 07:32 AM
Robert AMG's Avatar
Cls63 & C32
tap the y-pipe
The y pipe after the Supercharged?
Old Jun 9, 2009 | 01:48 PM
jturkel's Avatar
02 C32 AMG
yes.
step-by-step directions: http://www.slk32.com/pages/boostgauge1/boostgauge1.html
you can also use some electronic OBDII ones like DashDaq. They are really nice, but those are quite pricey (Dashdaq can be 549 or like 659 with Navigation) and not all of them are compatible, like i recently found out when i purchased ScanGaugeII.
Old Jun 9, 2009 | 04:12 PM
C32 AMG
yes.
I was just going to ask if you had found one yet that works to its full potential. Guess ScanGuage can be ruled out....
If I could just get accurate boost, IATs, and AFRs, I'd be happy.
Old Jun 9, 2009 | 04:17 PM
jturkel's Avatar
02 C32 AMG
yah leaning towards a DashDaq even though price is high. However, to accurately monitor AFRs, you will still need to purchased a wideband-02 sensor/kit since our ECU only reads narrowband O2. Zeitronix (spelling?) sells kits i think for like 150 that are compatible. the nice thing about dashdaq is the tons of features it offers and it might look cleaner than like 3 gauges, but it is more expensive.
Check out the DashDaq website. It's pretty legit. And I don't have nav, not that i need it, but i would consider getting one with nav
Old Jun 9, 2009 | 07:04 PM
Lenin's Avatar
I used DashDaq until my car problems started. I like it a lot. When my IC pump went, I knew right away what the problem was. DashDaq can also monitor boost using OBD2. No need to tap into the Y-pipe. It does not take as many samples per second as the Zeitronix boost sensor, but otherwise, works fine an is accurate. I have Zeitronix installed but did not get a chance to connect it to DashDaq before the car crapped out on me.
