Supercharger woes....not always on
I just dropped my car ('02 C32...80k...with a lot of NEW parts (cam, sc clutch/bearings, piston or two, ex valves...too much honestly) off at the stealership (RBM of Atlanta) because the sc works intermittently. No codes thrown, no nasty noises...just no go. If you've ever driven a C32 when the sc is out, you know what I mean...its got less oomph than a C240 4Matic wagon.
Has anybody ever had this happen?
When it happens, its not violent...just a loss of power.
The Bosch unit is standard. The Johnson CM30 (I think) is a nice upgraded unit that should last longer. Several sponsors here at MBW sell them.
I would also recommend investing in something like a CarChip http://www.carchip.com/Products/8226.asp to monitor your IATs and other things. Or you can go with a more sophisticated OBD2 reader. With over
80K miles on the car, you will need something sooner or later.
I like the sound of $150 better. I'm pretty mechanically inclined but haven't worked on this car at all. What are my chances of pulling this off?
and do you know any OBDII readers that have a display that ARE compatible and more of a gauge than a scanner? (like a scangauge, but compatible).....and that ISNT the price of a DashDaq?
Something with a display (sort of) that can also record OBD2 data was discussed here: https://mbworld.org/forums/c32-amg-c...2-monitor.html
Did you see this thread? What are you looking to monitor?
When I called back to tell them I didn't want them to do the repair because I could get the Bosch pump for $130 or the Johnson for $175 and simply do it myself...they'd already done the repair. My service manager there - whom I've dealt with more than I care to say - told me if I showed him that I could get the exact same part # for that amount...he'd credit me the difference off of the $495 cost (that's what MB charges for it!!!!).
Showed him this site: http://needswings.com/Bosch-Intercoo...schICpump.aspx
And he did it. Probably only because I've spent SOOOOOOOO much with them.
I think im having the exact same problem, plus some. i live in washington and i drove my car to reno nevada on a road trip I'm supposed to be doing the drive back to washington in a few days do you guys thing the car can make it 900 miles with that problem or im stuck in nevada till i fix the problem?
And finally having the secondary cats & resonator yanked tomorrow.
my 150hp 1.8T turbo was quicker when the i/c pump decide to take a dump.
weird
