First project complete......Plugs
Old Jul 23, 2009 | 09:12 AM
fergsc32's Avatar
2011 c63 AMG
After 2 weeks I tackled my first project of ownership...new plugs. Being an Autozome rewards member I picked up 12 NGK iridiim IX for just about 60 bucks.
All I can say is what a @#*& of a job it is to do plugs on this car and I do car projects/mods as a hobby, Jeez.
In retrospect, for those who are contemplating, I would have labeled the wires and taken off the coils. It was not until the last plug on the right side that I took a coil off, then I was like damn! should have done this to begin with. For me on this car, the hardest part was actually the removal of the old wires, as this was seeminly the first time they had come off.
So it was very apparent that the plugs were the originals, yet they were all exactly the same as far as color and wear which is good. They had been worn to just over .040.
The difference with the new plugs is night and day. Silent idle and far better throttle responce.
Next up.....IC Pump this weekend!!
Old Jul 23, 2009 | 09:21 AM
SilverBulletAMG's Avatar
C32 AMG
Congrats on your first successful journey under the hood on your new AMG! You sure picked one heck of a first project to tackle. I don't mind getting dirty and busting my knuckles, but there is no way I ever plan on changing my own plugs/wires on these cars. Watching my indy shop change mine, even with special tools and the know-how, it still looked like a total PITA.
Now that you've knocked that out, all your other projects will be cake.
Old Jul 23, 2009 | 09:33 AM
fergsc32's Avatar
2011 c63 AMG
Yah PITA is the appropriate phrase. I would put my self probably in the 85th percentile for ability on DIY car projects and this took me the better part of 3 hrs to do...I think alot had to do with how hard it was for the wire removal/install. I could do this in half the time if I did it again though.
I would also make a strong recommendation to others to purchase wire boot lubricaton. I found some after my 7th wire and after that, instal was 3 times easier to get that final click.
Old Jul 23, 2009 | 01:03 PM
jturkel's Avatar
02 C32 AMG
what did you gap your new plugs to? glad you were able to successfully switch them out
Old Jul 23, 2009 | 01:39 PM
fergsc32's Avatar
2011 c63 AMG
Technicaly they are pre-gapped to .039. but I never trust that so I checked and all but 1 were dead on so I left @ .039
Old Jul 23, 2009 | 02:45 PM
saer1one's Avatar
2002 c32 AMG 2012 c250 Coupe
good job, how long did it take you..? 3-4 hours..? not to threadjack your thread fergsc32 but since were talking about plugs, does anyone know from personal experience how the PULStar plugs compare next to the ngk iridium's..? ive been hearing alot of hype about these plugs claiming a gain of 10 hp and 6% increase in mpg's but those numbers seem too high for just plugs..
Old Jul 23, 2009 | 02:48 PM
C32 AMG
Originally Posted by saer1one
good job, how long did it take you..? 3-4 hours..? not to threadjack your thread fergsc32 but does anyone know from personal experience how the PULStar plugs compare next to the ngk iridium's..? ive been hearing alot of hype about these plugs claiming a gain of 10 hp and 6% increase in mpg's but those numbers seem too high for just plugs..
Do NOT be fooled. NO plug will gain you hp or mpg. The only gain would be if your original plugs/wires were shot, in which case any new plug would show gains based on your engine running more efficiently.
Due to PULStar's hype, and it is just that - hype, I will never purchase any of their crap. Just my opinion....
Old Jul 23, 2009 | 03:02 PM
saer1one's Avatar
thats exactly what i was hoping to hear.. when i heard about PULStar plugs and the hype, i thought of the "PATCH PERFECT" commercial where their claiming that their grass is on steroids and can grow thru concrete with out ever having water or sun light..
Old Jul 23, 2009 | 03:03 PM
jturkel's Avatar
02 C32 AMG
100% correct
Old Jul 23, 2009 | 05:12 PM
fergsc32's Avatar
2011 c63 AMG
Yes it took me 3 hrs plus..however, I could tell this was the first time this was done as it was absolutely ridiculous how hard it was to get the wires off.. some of them took 10-15 minutes of trying and swearing and trying and drinking etc etc etc.
Old Jul 23, 2009 | 07:24 PM
aho's Avatar
aho
03 C32 AMG
I feel like such a newb, I had no idea our cars took 12 spark plugs. Can you explain a little more about what's all involved with swapping out the plugs, I am entirely clueless! A step by step instuction would be very much appreciated!
Old Jul 23, 2009 | 07:51 PM
fergsc32's Avatar
2011 c63 AMG
There really is only 2-3 steps depending. Step 1 cold beer(s)
1: remove the intake tubes and the baffles that hold the filters. # 25 torx and the bafles just pop off the stubs. I did NOT remove the actual top along with the back intake attached to the Throttle body, buts thats only because i could not see how to get the back part lower tab off and i was already running late.
2: At this point, you could "choose" to remove the coils. I "highly" recommend this in retrospect . I did not but I learned my lesson. As long as you mark the wires. It is really very simple. Counting from the front of the car the 1,3,5 wires on both sides go to the TOP coil connect, the 2,4,6 go on bottom.
Standing on the left of the car the 1,3.5 wires plug to the RIGHT plug, from the right they plug to the left plug.. obvioulsy the opposite for the even wires. follow me??
The coils each have one single # 30 torx and the come completely out of the way.
Then its off you go to remove the plugs. You MUST have a universal joint spark plug socket, or a normal socket with a universal attachment. You also need 2 different extentions. I used a 3/8 ratchet.
I would also strongly suggest spark plug wire boot lubrication, it will make plugging them back on far far easier.
The far back plugs are more difficult, especialy the right side last 2 but without the coils(doh !!) it will be WAY easier.
With the NGK's they have kind of a double washer.. designed to compress, you need to tighten until the compression is done.. no further.. or follow torque specs
Have fun
Old Jul 23, 2009 | 09:07 PM
aho's Avatar
aho
03 C32 AMG
Excellent! Thank you so much!
