C55 Died - Battery/Alternator Visit Workshop Error
The car drove fine at first, but a few hours later the car started to die on me. The ABS, SRS, and other lights lit up on the dash. The radio showed a low battery voltage error and then all electrical power started to turn off. The headlights stopped working and the car was sluggish. I was lucky that this happened right after I exited the freeway. I managed to drive to a safe neighborhood and parked while waiting for a tow truck.
Getting the tow truck to lift the lowered C55 was an issue. I had to call 2 different tow truck guys to attempt the tow. First guy came and right away he told me that my front bumper and rear tail pipes would be damaged from the tow. This guy seemed convinced that there was no safe way to pull the car onto his flatbed. He told me to sign a damage liability waiver, but I declined. I sat there deciding what to do. I didn't want to damage the car, but damn I was stuck and didn't really have any other options.
I decided to take my chances and call a second tow truck company. The second tow truck guy was really helpful. He used 2 blocks of wood to help gain extra clearance onto the flatbed. My girlfriend and I taped up the front lip with semi-thick bathroom towels. The C55 was slowly pulled onto the flatbed with the front bumper hitting the metal flatbed. Luckily the towels cushioned the lip and no scrapes occurred.
I was so relieved there was no damage to the car. The car died at 11pm and it was now 3:30am. We drove to the nearest dealership and I tipped the tow truck driver $60 for his help and patience.
I'm guessing my alternator needs to be replaced. Good thing for extended warranty and AAA
Cushioning my front lip with towels really helped save the front bumper.
Hope everything goes well, and for anyone reading this who doesn't know, if the red Battery Alternator Visit Workshop light comes on it means that you are running completely off of the battery and your car *will* die in a matter of hours. This is not like an orange check engine light that you can just drive on most of the time.
Take the car to the dealer asap if possible. Don't wait and go through any hassles of towing the car.
Especially if you have a lowered vehicle.
I guess several other members have had the same issue.
It seems like these MB alternators don't last that long
Also the alternator in our cars are a bit of a PITA to get to, so it would be annoying to take it out, replace the VR, put it back and have to do the whole thing again.
Any advice on whether all 3 parts should be replaced or just the regulator?
To answer your question, the alternator is probably fine, just needs a regulator. The battery might not come back from a discharged state or if it does it might not hold a good charge for a long time. A new battery and a tender would be good insurance. I wired mine directly to the battery and so it's real easy, clean, and no screwing around with aligator clips. The battery posts have a threaded bolt that the pre-wire lead drops right onto. Just install a couple of nuts and it's done.
Hopefully you aren't paying too much for the repairs.
As for the alternator, they have yet to install the regulator and will tell me how that looks when complete, however, the mechanic said that based on his experience the alternator should test just fine.
As a preventitive measure should we be changing the voltage regulator every 4-5 years?
The battery tender sounds like a great idea? Do you have more information on which type to buy?
Thanks again for the invaluable info.!!!
