WTB: Supercharger Pulley
C32 AMG, Trans Am, Lincoln Navigator, E36 325i
![Thumbs up](https://mbworld.org/forums/images/icons/icon14.gif)
Hey fellas,
I decided to order an aftermarket pulley from Code3 Performance. Brandon was very helpful in answering my questions. The customer service was excelent. The order was placed Wed. and wouldn't you know, it's already here! There, sitting on my porch was the recipe for a smile all weekend
So, with what little energy I had left from work, I removed the small air pipes, and the belt by way of the tensioner. The pulley requires more torque than I can apply to remove it, so i'll swing by the hardware store in the morning for a nice metal strap wrench. I'll be sure to update the site with my driving impressions when I finish.![thumbs](https://mbworld.org/forums/images/smilies/thumbsup.gif)
Albert Hernandez.
Albert Hernandez.
In fact, I would have ordered my Intercooler Pump from Code3 instead of APE, but they were out of stock. That will arrive next week I believe.
![naughty](https://mbworld.org/forums/images/smilies/naughty.gif)
Albert Hernandez.
03 C32 AMG
follow this link, at the bottom of the first post is a PDF download that gives you a walkthrough on the install.
https://mbworld.org/forums/c32-amg-c...ns-thread.html
#32
2003 porsche 996 turbo
had to use a deadblow hammer to get my oem pulley off. it was a b*&tch to get off!!! the bearing inside the pulley was failing and burnt.
#33
first time, definitely used a hammer too when it was hot though, but not hitting directly on the pulley. hit a rubber pad i placed over the pulley so as not to cause dinks/dents/scratches
#34
after much waiting my c3 is installed! worth the wait. torque is awesome car launches and just smokes the tires. definately have to practice my takeoffs
#35
03 g35 coupe...........02 c32 Sold
you don't need to use a hammer to take off the pulley when its cold. you have to pull it off at a angle. you can't pull it straight off. if you angle it comes off easily.
#36
because the bearing was failing on my oem pulley it WOULD not come off. engine was cold but the grease from the bearings was burnt onto the s/c shaft and acted like glue. using a rubber hammer and a fiberglass deadblow hammer i was able to break the pulley loose and remove it. then clean the shaft and the c3 slid rite on. i now have a new bearing to go into the oem and keep as a spare
#38
Would be even better if you had a matching LET Tune to it. Made a world of difference for me. C#@Used still cant catch me
![EEK!](https://mbworld.org/forums/images/smilies/eek.gif)
#39
