installed a new pulley today
We only did about 8 pulls in the course of 15min or so. I came to the conclusion I hate modding my car in the AZ heat. Shop temp was 107 degrees and 31% humidity.
On the plus side the car feels smoother, strangely enough. Over all it just made my car feel better. Kind of one of those things you cant explain. Maybe the Renntech pulley has less vibration than a stock 152mm pulley I was using.
IMO, the jury is still out on what kind of power numbers I will see with the new pulley and cooler temps. Also A/F needs to be adjusted. I need a bit more fuel.
Right now, thats it for performance mods until it cools off. In this heat its even more important to do back to back same day dyno pulls. I'm 450 one day then 435 then back to 450hp. Its getting even harder to tell where my car really stands at this point.
I'm sure your car is faster. The heat is really killing our cars. I was posting up in the header thread the other day about my racing Brock. You were in my car that one night in March or April after my pulley and tune when I ran Brock. And he only pulled a little bit (that was with his longtubes).
I raced him two weeks ago with Trevor in his car, and he pulled me like 2 cars WITH the addition of my headers. You can really feel the difference. When I went out the other night and it was 80 compared to the 105 I ran Brock in, my car was insanely fast. Those temp differences are causing the confusion.
I'm not planning on putting my car on a dyno, going to the track, or seriously taking my boost numbers until at least early October. It just isnt worth the aggravation.
What are your IATs though? I would imagine yours are significantly lower than mine (idk what mine are tho) considering you are running two heat exchangers, a large pump, and less boost than me.
smaller supercharger pulley = more boost
example:
stock C32 pulley (158 or 168, i dont remember) = 14.5PSI
178mm Crank Pulley ~17 PSI
181mm~19 PSI
185mm~21-22 PSI
We didnt monitor it today but I may be pulling some timing in this heat.
If anything is a good indicator the TQ number down low went up, and thats before the motor can really be affected by the heat outside and the engine.
It seems ironic that as soon as the heat hits out here everyone from AZ starts complaining of the effects on the cars. My self included.
Just for S&G I checked the DA from Dragtimes at Speedworld and it was 4988ft! and that was at the 9pm time slot! The time I race at. Thats like racing a mile in the sky or not to far off!
New found respect for our AMG friends in Denver.
edit: just talked with brock. he ran a 13.5 @ 108.2 at 6300 DA. C6 Z06 was a 12.4 at 115. New driver apparently. Just to show how much temps and DA can make an affect. I think altitude kills N/A more than F/I but temps kill F/I like our cars more than N/A imo. Not sure if that is proven anywhere, just my personal experiences with both.
if the DA drops below 2000ft I will put down a fast time. I've already started my Christmas shopping to see if that helps make the cooler temps get here faster.
Retune should help a bit but the most help in consistent power will be the IATs you're getting at the shop/dyno which is not helping at all at 107 degrees as the temperature in there. Easily I wont be suprised if you make more power on the street and especially during the AZ nights vs. what you dynoed at the shop. This is easily the case where the IAT themselves can't be too low due to insane environmental temperatures and humidity. It would be nice to dyno on a cool AZ night vs. the day, I won't be suprised if it makes a good amount more of power and torque especially if you retune the ecu.
Get that 180mm, Race gas, Slicks or DRs, and head out on a MUCH COOLER temperature time period. How I see it the CM30 could be on there along with an upgraded HE, they won't be able to help a bit if what you have around you is scorching heat.
The formula of Cool temps, consistent cooling mods, and a nasty power such as what you got, and traction = ownage!
Sure thing Your filming. Trust me, you know my lady she will love you if you take over that roll... And yes you can use my slicks any time. Turk going for the 12's this winter and its going to happen for sure.
I have a custom cooling combo on my car. Twin heat exchangers big pump and independent ran system. Dont think its helping in this heat much. So again I agree with you. cant cool down a car with hot air.
I ran my outside temp sensor down to my intercooler "y" and I've come to the conclusion that the temp numbers it reads are way wrong.
you definitely need to get a legit IAT gauge then. thats why i'm getting that dashdyno. that way you really know when and why your car is running well or is running like a$$.
Couldn't agree more myself, a common case with those on boost is to have good IATs, high heat temps don't help no matter how good of cooling you got on hand. Be patient as things should shape up soon, once the ECU gets a retune and you have some cooler temps, things should turn out pretty good.
Since you got a custom cooling setup for your car, why can't you make a custom cooling setup for the shop and the shirts you wear?
I see it now you'll tell others "I own a C55, even though it lacks ventilated seats from the factory my ventilated a/c shirt makes up for that feature MB left out."
I'm getting this... Its the last one on the page.
http://www.aircraftspruce.com/catalo...davtron307.php
model 307FD? pretty steep....though i suppose you cant go wrong with an aircraft gauge on a car? has to be pretty damn accurate im guessing lol
