2005 c55 Dyno after exhaust work
I will have a pic up in the next few days, once the shop emails it to me.
The pulls were done on 2 different days, but the only difference was the out side temp, the first pull it was 86 deg, today it was 80 deg, humidity, barometric pressure was damn near exact, the dyno had a correction factor of .01.
AMS 300cell 2nd cats = 10HP / 12 TQ Dyno Dynamics
Hooley 2nd delete = 13HP / 19 TQ Dyno Dynamics
Bryan's 2nd delete = 16HP / 22 TQ (dyno unknown, maybe dynojet?)
What is most impressive is that just by going from a 400 OEM to 300cell metal core cat you get roughly 60-75% of the gains with almost no change in emissions (for those that are very environmentally conscious). With that said, 2nd cats do give you more sound than stock but still refine the exhaust note more so than straight pipes, so the high flow cats are a good alternative to going complete straight pipes for those worrying about not passing the visual inspection.
More dyno info (brand & model dyno, pre/post temps/humidity, etc) would be appreciated just to gather more data for the AMG community as a whole.
~AMS~
the resonator delete will drop you a couple pounds and alter the sound; no change in power. high flow/race primary cats will add you maybe a couple hp, and deleted secondaries have not shown any power, maybe 1whp? mostly deleting the secondaries on the C32 have just made the car louder, not changing the sound, but making it louder.
however, i have heard that if you run headers, you may see some smallish gains from deleting the secondaries, resonator, and running high flow primaries as the stock exhaust manifolds were the main bottleneck in the exhaust, and taking care of all those other parts just fine tunes it for perhaps a little better exhaust flow.
It appears there is a linear relationship with gains from catalytic converters and engine displacement on these AMG engines (FI or NA seems irrelevant). The smaller displacement V6s simply don't show much gains (if any at all). This seems counter intuitive since both should be moving roughly the same air in case of C32 vs. C55, but that's just how it works sometimes.
Check out the shop I had the dyno done at www.houseofboost.com
http://www.houseofboost.com/blog/
Scroll halfway down for pics.
