Is it possible to install C55 steering wheels on a C32?
Old Sep 24, 2009 | 03:09 AM
Quicktwinturbo's Avatar
CLS, SLK, ETC
One of my friend is thinking about doin the swap and he would like to know if this conversion is possible. Will all the buttons work (incld pedal / button shifts)?
Has anyone tried or done this conversion?
Thanks in Adv..
Old Sep 24, 2009 | 07:28 AM
Lenin's Avatar
2002 C32 AMG, 2013 GLK 350/4, 2015 E63S AMG Wagon
The conversion is possible but not cost effective. Never heard of the button shifting working on a C32 since that would require transmission changes. Tell you friend to give it up.
Old Sep 24, 2009 | 12:31 PM
francoisisp's Avatar
AMG
there is guy on this forum that did a slk swap with padle shifter, the whole works but it was quite pricy i saw the pics about 2 years ago on the forum Ill try to find it
Old Sep 24, 2009 | 01:06 PM
Phil_W's Avatar
C32 AMG
I'm interested too!
Please with pictures.
Old Sep 24, 2009 | 09:04 PM
CLS, SLK, ETC
Sweet~ please let me know! When you say SLK swap, that includes tranny as well?
1qikctr's Avatar
Merc power
In order to run the paddle shifter, i believe you need to have the ECU too. Tons of work...but, best of luck.
Old Sep 25, 2009 | 12:40 AM
CLS, SLK, ETC
Sounds like PITA......
Old Sep 25, 2009 | 12:58 AM
1qikctr's Avatar
Merc power
PITA is correct my friend lol. thats why i left my shi* 32 interior alone. Thank goodness i only drive mine once or twice a week ha.
Old Sep 25, 2009 | 01:06 AM
CLS, SLK, ETC
haha yea~~ I told him to F it... It's not gon happen... lol
Thank you all for your helps!!!
Old Sep 25, 2009 | 05:16 AM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
huh? you don't need a transmission change.
it's all in the coding of the TCU which is PITA. If you know how all that coding works it's doable. Sunil did it on his 2003 C320 with the shift buttons.
Old Sep 25, 2009 | 09:36 AM
Lenin's Avatar
Frank,
That's what I meant. Sunil did a lot of other changes to that car including D2B to MOST conversion. That and the TCU re-coding is not trivial. Like everyone said, it's PITA. Also, I'm not sure if the C320 TCU is the same as the C32 TCU. It may be.
Old Sep 25, 2009 | 05:20 PM
Robert AMG's Avatar
Cls63 & C32
I have a C32 2002, i have done this project successfully with paddle shifter, but with a clk550 steering wheel, the work is done without touching the TCU, i have a friend who works with car electronics, all he did is that he made a small board that he connect it to the steering wheel and to the shift knob electronic, so when you press the paddle shifter is like you press the shift knob nothing else without touching anything else and is it working very good no problems, it is now on my car from 4 months.
Old Sep 25, 2009 | 05:25 PM
Phil_W's Avatar
C32 AMG
hi, thats absolutley same what i want to do!
It shouldnt make problems!
I say it easy: The shift knob only have 2 switches, witch shift up and down if you press it. The paddles dont do anything else, thats only 2 swichtes, so you can connect both switches
Old Sep 25, 2009 | 05:34 PM
Robert AMG's Avatar
Cls63 & C32
it is not easy, the 2 switches are connect to one so you have to deal with an electronic board that made data 0 volts for + or 4 volt for -, you have to ask a person who knows about data transfer in MB. i will ask the one who did mine in the few days so i can give you more.
