TemjinX2's pulley Saver kit review
Old Oct 10, 2009 | 03:53 AM
TemjinX2's Avatar
03 g35 coupe...........02 c32 Sold
great input guys...keep it up.
Old Oct 10, 2009 | 05:12 AM
razormb's Avatar
CLA
Ziptie the lower coolant line to the reservoir hose and it will be fine.. tying the coolant lines together wont hold up and will rub. I had the same issue at first.
Old Oct 4, 2010 | 01:17 PM
c32used's Avatar
LET C32 2002
Question
Hey guys I had the idler go out on me last night..thank God it was near my house..after some night inspection it was found it's all idler pulley related..opened my hood saw belt off and pulley is on under carriage cover as noticed by hitting the bottom of cover and it bounced..well anyways I haven't yet been able to recover the idler pulley but the bolt for it is toast..I honestly don't know if the idler was redesigned one sold in new 185 kits anyways been reading about this pulley saver kit by Needswings...please point out where to buy I presume needswings but is there somewhere else? On average to all who suffered idler pulley damage what required being replaced?
Old Oct 4, 2010 | 01:45 PM
Newzchspy's Avatar
PLAID
Vic you had a very typical "idler pulley" problem on a crank pulley modded car. Havent seen these on the Code 3 SC pulley changes. Go to Needswings.com for the kit. It states: With the larger 185 pulley the idler is now turning at a speed of 3.08 times the engine speed or about 18,500 rpm at full revs. This is excessive and addressed to decrease stress on the pulley and increase its life span.
The kits is about $200.00
Old Oct 4, 2010 | 01:51 PM
loudandheard's Avatar
C32/C55 AMG
I'm surprised I never saw this thread. I would highly recommend getting the kit as well. I had bought a 178 crank pulley a while back and remember reading all the horror stories of pulleys going bad and reeking havoc. So I became paranoid and kept hearing odd pulley related sounds, but once I installed the nws psk, the pulleys were much quieter and a lot smoother. I did notice that the belts seem to be a lot tighter now.
I have been using the kit for what seems to be almost a year and every thing has been great.
Old Oct 4, 2010 | 02:18 PM
jturkel's Avatar
02 C32 AMG
+1.....the kit is great. i got mine for my 185 kit.
and to Vic, i had the idler with the high speed bearing but it was on the way out anyway within 3 or so months, so i got the pulley saver kit. no problems at all! all smooth sailing!
Old Oct 4, 2010 | 02:32 PM
  #32
c32used's Avatar
LET C32 2002
Question
I presume this link is it...
http://needswings.com/Pulley-Saver-K...gs-psk185.aspx
Listen guys checkout these pics I was going less then 1mph out of my driveway when I heard something from engine bay area fall as I turned my wheel...I honestly after examining bolt and idler feel it hasn't much damage...the location where the bolt goes only has the groves a little messed up at beginning but the idler and bolt have very little damage the belt don't look bad either..give me opinions? I'm thinking the screw got loose over time and by miracle it came off before I can rev engine to force further damage...I was thinking of putting it back on and once I get the PSK have it installed...what you all think?
Attached Thumbnails TemjinX2's pulley Saver kit review-photo-1-2-.jpg   TemjinX2's pulley Saver kit review-photo-1-3-.jpg   TemjinX2's pulley Saver kit review-photo-1.jpg   TemjinX2's pulley Saver kit review-photo-2-2-.jpg   TemjinX2's pulley Saver kit review-photo-2-3-.jpg
Old Oct 4, 2010 | 02:34 PM
  #33
c32used's Avatar
LET C32 2002
Question
more pics
Attached Thumbnails TemjinX2's pulley Saver kit review-photo-3-2-.jpg   TemjinX2's pulley Saver kit review-photo-3.jpg   TemjinX2's pulley Saver kit review-photo-4-2-.jpg   TemjinX2's pulley Saver kit review-photo-4.jpg   TemjinX2's pulley Saver kit review-photo-5-2-.jpg
Old Oct 5, 2010 | 06:12 AM
  #34
TemjinX2's Avatar
I would just use the psk kit. Its been proven to work over this past yr. My EC idler pulley was on its way out after about 6000 miles and this is the new version.
Old Oct 5, 2010 | 08:47 PM
  #35
gt4awd's Avatar
2005 Pontiac GTO 6.0 LS2 - Blue
Looks like the bolt came loose. You can see where the pulley bearing was spinning, and grinding...
Old Oct 6, 2010 | 10:39 PM
  #36
ML500K's Avatar
C32 '02
+1,
1) peace of mind
2) increase pulley bearings reliability
3) more SC belt wrapping
PSK FTW!
Old Dec 3, 2010 | 12:21 PM
  #37
mdncn2762's Avatar
1992 Toyota Corolla, 1994 Chevy C1500, 2002 C32, 2012 Prius, 2013 Toyota Sienna
I bought a brand new EC 185 kit from a member a while ago. Im getting ready to install it along with a PSK. Can anyone verify that this Idler Pulley is the correct new 19,000 RPM bearing? It has 0 markings on it. I dont wont to put it on if it isnt.....Maybe Eurocharged can help???
Attached Thumbnails TemjinX2's pulley Saver kit review-dsc_0223.jpg   TemjinX2's pulley Saver kit review-dsc_0224.jpg
Old Dec 3, 2010 | 05:26 PM
  #38
gt4awd's Avatar
Uhhh, you won't use this idler with the PSK anyways.
Old Dec 3, 2010 | 06:35 PM
  #39
mdncn2762's Avatar
Damn thats right...it gets replaced with this...Thanks
Old Apr 25, 2011 | 12:30 PM
  #40
c32used's Avatar
LET C32 2002
Thumbs up
thanks I think this will help
Old May 2, 2011 | 11:59 PM
  #41
c32used's Avatar
LET C32 2002
Thumbs up
Well it's done..thanks to all the great pics and input in this thread...
