C55 AMG Intake???
Thanks,
Chris
The E55 and renntech airboxes use the same stock filters as the C55 intake. The renntech airbox can hold more volume. over the stock and E55 intake.
IMO, based on countless dyno runs. There is no gain to be had with using a 55K airbox on a NA C55.
see threads:
https://mbworld.org/forums/c32-amg-c...dent-dyno.html
https://mbworld.org/forums/c32-amg-c...rbox-dyno.html
see threads:
+1, plus not having an engine cover isn't very aesthetically pleasing.
see threads:
Yeah, its funny how we were told the E55 boxes would make about 10rwhp on the N/A V8s! Sorry, I'm still a little bitter......
OP: search fro a used Renntech airbox. They pop up from time to time.
If people want an tube style intake for the C55 I can get them made. its not a problem at all. Truth is though I don't know it it will make any power no matter how nice it comes out.
just look on youtude seach abracing
The main reason this is the case is the post air filter volume and shape of the airbox on the AMGs is larger. Renntech merely continued this trend with their CF/OEM AMG hybrid airbox and make the cavity even larger with a smoother bend at the end. Increasing airbox volume pre-filters won't really do much of anything.
Regarding tube based intakes.... They are metal (heat soak) and aesthetically unappealing. For this reason most people won't do them (regardless if they make real power or not, which has yet to be 100% confirmed). They just look ugly (no offense to anyone)
The real reason this is the case though has more to do with the overall system itself. AMGs come with amazing OEM airboxes (far superior to BMWs designs). Almost all of the restriction on these AMGs is on the exhaust side (specifically on the front half of the exhaust system which are never almost always off the shelf non-amg components with a few rare exceptions). Everything after the 2nd cats on almost all AMGs (except C36 & C32) is free flowing and provides no power advantages and therefore should never really be touched. Unless you fully unlock all of the exhausts potential (high flow headers, high flow secondaries and/or high flow primaries) then it won't make a difference what you do. With a fully modified exhaust system, software, pulleys & etc, THEN you might makes some decent gains but there is yet to be an financially viable/reasonable option for most people to upgrade the OEM AMG air boxes that comes on these AMGs (showing AMG really did their homework and tuned the airboxes for exactly what their engines needs, and then some).
Moral of the story: Just slap in some K&N filters and put a fork in this thread
Hope that helps.
FYI, the bottom half of the renntech airbox is from your stock airbox. They smooth out the interior and raise it about and inch then add the cf on top. When a first purchased mine they wanted my stock one for a core. I am sure they don't do that anymore but once they did.
Andy
Andy
