Another C55 Record
Old 11-23-2009 | 01:05 AM
hooleyboy's Avatar
Former Vendor of MBWorld
C55,SL55,C63
Another C55 Record
Just getting back from Famoso. It was a great time for sure.
I had traction issues all day long. I ended up running an 11.55 @ 120mph with wheel spin. I was spinning so bad it sent my trans into a funk. Causing the clutch packs to slip. Sadly I think my trans is shot from the years of abuse racing and its time for from new clutch packs.
At the end of the day my trans felt like a drunk man in bar fight. Sloppy, but getting the job done. You can have all the TCU tuning in the world, but if there is nothing left to grip than it is what it is.
Here is the video of my car setting a new record while getting destroyed by a 10.1 Mustang
http://www.youtube.com/watch?v=tbsz3OLYWeQ
Old 11-23-2009 | 01:16 AM
jturkel's Avatar
02 C32 AMG
nice run Hooley!
is that Rich I hear in the video? haha
Old 11-23-2009 | 02:49 AM
AMS Performance's Avatar
AMG
Thatta boy hooley, congrats on the run.
Get it rebuilt with tighter tolerances so there's alot less clutch slippage & quicker shifts, it should be able to handle 800+ no problem.
Old 11-23-2009 | 03:31 AM
BenzoBoi's Avatar
Super Moderator
W221
It was awesome seeyin yer car run! Congrats again on the great time!
Old 11-23-2009 | 10:00 AM
hooleyboy's Avatar
C55,SL55,C63
Thanks alot, Thats the plan for the trans. its not 100% junk. It shift ok. and daily driving is fine. I just really gave this thing a beating this weekend.. So before I tie it in a knot, I might as well fix it now.
Its crazy I run an 11.55 and I think it feels like crap. Yet on a 12.1 pass I think it runs great. Only to be let down when I get my time slip.
I had to change my tire pressure 8 times! I run 26psi here in AZ and it works great. I got to Famoso and at the end of the day I got 12psi in the tires and I'm still spinning.
Old 11-23-2009 | 10:04 AM
JonMBZ's Avatar
06 C55, 09 E350
I cant remember if you have a LSD installed... So do you or do you have plans to ?
Old 11-23-2009 | 10:17 AM
hooleyboy's Avatar
C55,SL55,C63
LSD is coming very soon.
Old 11-23-2009 | 11:27 AM
JonMBZ's Avatar
06 C55, 09 E350
Cool I didn't think you did that should make you a little quicker hopefully. Are you going with Quaife? I know evosport has a nice looking one, but not sure if they ever finished developing it.
Old 11-23-2009 | 12:11 PM
alumar's Avatar
2019 E63s AMG
Sheesh, 120mph ...thats nasty ... def going to need the A/F correct to play in that territory
Old 11-23-2009 | 01:50 PM
F1Bobby's Avatar
From: People's Republic of California (Southern Region)
C55 AMG, CLK550
Bravo on the run!
Old 11-23-2009 | 05:05 PM
Newzchspy's Avatar
PLAID
Me too, I should have the Quaife in by the next few weeks!!! However, racing season is over in IL.
Mike, you ran that off of ESP (ESP OFF) then?? What a great run.
Q: What the heck was that Mustang running??? 133 MPH. WOW!! He had a good hole shot on the stang BUT he started running out of breath at the end. Another qtr and you would have caught him!!
Old 11-23-2009 | 05:12 PM
320 dreamer's Avatar
2003 porsche 996 turbo
hey hooley i think this will fit in your lsd plans! looks pretty sweet but not made for my 32
http://www.wavetrac.net/
Old 11-23-2009 | 05:17 PM
jturkel's Avatar
02 C32 AMG
Hooley actually runs at the track in dyno-mode.
Old 11-23-2009 | 05:36 PM
AMGSC's Avatar
2006 Weistec 3.0L SC'd C55, 2006 MaxPsi PT6466 Turbo'd M3, 2019 Maserati GTS , 2020Alfa Quadrifoglio
Nice run! Too bad I left before you hit that record.
fyi...After talking to Richard, I think the MAF is the number 1# constraint on our cars. There is a company called ABACO http://www.abacoperformance.com/ that makes oversized digital MAF sensors/meters that are fully programmable and scalable. I don't really want to move my MAF sensor the way you did it because it is still only a partial solution plus the fact that I have dual cone 3" intakes and you have a single cone intake.
Once I get this oversized MAF, I should be able to add another 4psi with a 160mm crank pulley (stock is 150mm) coupled with my 65mm (12psi) SC pulley and reach 16psi safely on a 9:1CR motor. I was told by Kleemann that I would need to upgrade my fuel pump in addition to larger fuel injectors.
Again Congrats and I learned alot from your team and wished I was ready to run except for that stutter problem caused by the MAF.
Old 11-23-2009 | 05:49 PM
hooleyboy's Avatar
C55,SL55,C63
Dyno mode all the way. As long as you go to the long turn off it wont tax the brakes to much. You get alot of feel when racing in dyno mode. If you havent tried it you might want to give it a shot. It works for me, but I'm not sure how someone else would like it.
Yeah that Mustang was crazy fast. I was going to let him just run and then do my pass, But I forgot.
Newz, your dead on. I said the same thing after the race. At the end he was not pulling on me. I looked like he had big 4.11's in the rear end or something and was just about at its limit for his setup. He nailed a 1.45 60ft. How he did that on this track was insane.
Old 11-23-2009 | 05:52 PM
hooleyboy's Avatar
C55,SL55,C63
Some more runs. Some OK some bad.
http://www.youtube.com/watch?v=P7gEg__GBn0
http://www.youtube.com/watch?v=GUtzKlpMcfM
http://www.youtube.com/watch?v=MRKy5Oe3nyE
Old 11-23-2009 | 06:05 PM
Newzchspy's Avatar
PLAID
and people say RT doesnt matter (The stang must've had a good one as well, do you know what it was from the slip??? ) I still say BS, it totally matters when 2 cars are running against each other. If you're going it alone, I agree that its no big deal BUT when you're draggin against a car like that 'Stang, RT makes helluva lot of difference. A 1.45 60 ft means he had big meats on the back and was really hooking too.
Mike, do you realize that your time was only a .18 click away from George's Twin snail Corvette that I raced last fall??? He ran a 11.32. Man, thats a great run, NOW if you can just get that Quaife and the trans fixed too, you'd be low 11s.
Old 11-23-2009 | 06:10 PM
Newzchspy's Avatar
PLAID
C63 v C55!!!
http://www.youtube.com/watch?v=P7gEg__GBn0 Watched it: *** 12.74 at 115, barely quicker than my C32; Jake's car (C32) would have taken it!!! Not impressed with that particular C63 for sure!!!!! ***
http://www.youtube.com/watch?v=MRKy5Oe3nyE[/QUOTE]
Old 11-23-2009 | 06:22 PM
hooleyboy's Avatar
C55,SL55,C63
I was more disappointed with the supercharged M3 E92s. They just make no torque for a drag race. Not sure they liked my plate either.
Old 11-23-2009 | 07:07 PM
c32AMG-DTM's Avatar
2008 A8L, 2002 996TT X50, 2009 X5
Sigh... here we go again. You're effectively misquoting everyone who's chimed in about RT in any of the threads where it's been brought up in the last year or so.
Of course RT matters in a heads-up race, if the race matters to anyone or counts for anything. It just has zero impact on ET, 60', MPH, etc etc.
It really isn't that complicated...
/rant
Hooley - great job on setting your new record - chopping a quarter-second off at your ET levels (mid-11s) is huge for this platform... congrats.
Old 11-23-2009 | 07:08 PM
Viper98912's Avatar
Current: C217 V12TT AMG Previously: C55 AMG, SL65 AMG
wow, very nice.
Old 11-23-2009 | 07:10 PM
AMGSC's Avatar
If he can enlarge the MAF sensor/meter via http://www.abacoperformance.com/ then I'm sure this platform will not be a limitation in competing with the E55s and SL55s. In fact, I would even venture to say he can challenge for the overall MB top ET and Traps on Dragtimes.
I spoke to ABACO (Brian) and for $425 + $50 file transfer fee, you can run as much boost as your engine can handle without the ECU interefering and causing the stumble/stutter problem. Of course fuel injectors and fuel pump would need to match the increase in boost.
Old 11-23-2009 | 08:29 PM
JonMBZ's Avatar
06 C55, 09 E350
I just got around to watching the video, wow your car looks hot! I seen it run before, but it was at night
Old 11-23-2009 | 11:52 PM
1qikctr's Avatar
Merc power
I'm soo proud ! seeing those vid... sniff sniff you go Hooley!
Old 11-24-2009 | 12:04 AM
MBH motorsports's Avatar
C63, SL55, E55, CLS55, ML63, C55
LOL, It was good to be one of the fastest MB out there. The M3LOL plate was living up to its name. Even supercharged E92 M3's got nothing on me. Now thats a good feeling.
If you guys ever get a chance to meet Splinter he is a great guy. I wish I had more time to talk with him. These race events are like work.. In a fun sort of way.
Quick Reply: Another C55 Record
