modding c32 with high miles..
![Question](https://mbworld.org/forums/images/icons/icon5.gif)
I've been browsing a bit, but havent been able to find the real answer Im looking for....
what is everyones thoughts about modding a high mileage c32?
say your car has 100k or 120k, do you guys think it is safe to go all out and run a 185mm pulley if you take all the proper precausions with the larger HE and IC pump and intake with a tune?
more boost= more strain on the engine, so will it still be as reliable and last?
Obviously it is probably better to do this to a car with low mileage, but what are your thoughts?
My power steering pump went out a few months after installing the 185MM. C32 had 90k miles on it. I think engine internals should be fine higher mileage, but coolant pump, steering pump, alternator, etc, might fail quicker with the 185MM...
thanks!
took it in up in Big Bear right next to the lake as you can tell![thumbs](https://mbworld.org/forums/images/smilies/thumbsup.gif)
thank you!
well i already have a johnsonCM30 and already replaced my alternator....so 185 here i come!
thank you!
so 185 here i come!
