wheel cleaner
Old Nov 29, 2009 | 01:52 PM
MAXC55's Avatar
wheel cleaner
I just removed the wheels from the C55 for the winter wheel set up and realized the inside of the rim has brake dust that appears to be pitting the inside of the rim. I clean the inside of the rim the best I can each and every time I wash the car but this pitting has occurred and wont come off easily.
I have tried waxing and many cleaning solutions. Has anyone discovered a trick to removing this annoying mess?
Thanks for your input.
Old Nov 29, 2009 | 03:00 PM
mercdream's Avatar
w203 se,w204 sport
I had that in two of my wheels w203 180k ,less than a 2years old with24k miles ,dealer replaced under warranty (ps probably they will say never happened before!!
i do clean my car also regularly too
Old Nov 29, 2009 | 04:02 PM
320 dreamer's Avatar
2003 porsche 996 turbo
try meguires wheel cleaner and a medium brush. let it set for a few minutew. may not get it all off but worked well on my oems which had yrs of buildup before i got them
Old Nov 29, 2009 | 06:32 PM
Viper98912's Avatar
Current: C217 V12TT AMG Previously: C55 AMG, SL65 AMG
fyi, wheel cleaners can tarnish and stain the finish on brake calipers. careful how you spray it.
I just use soap and water, and a brush if necessary. for the inside of the wheel, a good rubdown is good enough for me. unless you're at a show, no one's looking at the inside of your wheels.
Old Nov 29, 2009 | 07:45 PM
TemjinX2's Avatar
03 g35 coupe...........02 c32 Sold
just make sure you use a wheel cleaner that is clear coat friendly. Meguiars is what i use as well.
Old Nov 29, 2009 | 10:04 PM
1Lop2K5C's Avatar
C63
I used this stuff call P21S for my aftermarket and OEM wheels. Its the best stuff I have used yet. Suppose to be easier on the clear coat.
Old Nov 29, 2009 | 10:11 PM
Phil C55's Avatar
2006 C55 AMG White/Ash
+1 on P21S, it's made in Germany and will not stain wheels like some cleaners that clain to be safe for all finishes. I use Wheel Wax too, it will get any brake dust off that can be removed and leaves the wheels slick and brake dust doesn't stick. The only problem with Wheel Wax, is if you do go ahead and use a painted wheel cleaner instead of just soap and water, the cleaner will remove the Wheel Wax as well.
Old Nov 29, 2009 | 10:16 PM
AlanG's Avatar
Carless
I have had good luck with eagle 1 wheel and tire cleaner. I know it has mixed reviews on the web, but has always worked great for me (note:I have never had anything other than oem wheels, so I have never tried it on diffent finishes). Might be a good thing to use, especially for the inside of your wheels.
