C32 Custom Intake
#51
as far as airflow, if you look at your dyno, you actually lose power as you approach redline. the hp line tapers downwards....and i'd bet that is a combination of timing being pulled because of high IATs and/or insufficient air flow (perhaps because of not having a direct flow of air to the filters).
#52
either way, finish up that intake and then lets critique this more seriously, since this is not the finished product. GL with the intake!
#54
for some reason, i forgot to mention in my first post in that thread that i had a heat exchanger in, but i did.
as far as 3rd versus 4th gear, i'm not too sure to be honest.
#55
C32 AMG, Trans Am, Lincoln Navigator, E36 325i
Great job on the intake, especially for the money! I think the results WOULD be very different with it on the street though. 35F, no way is the engine bay going to ever be that cold. The added heat and a normal warm day could cause detonation. At the minimum, timming would be pulled to keep from detonating.
Bottom line, I like the project. It's a little too "honda" looking on the C32 for me, but the heat is a real concern. With my Subaru, changing the intake with requires a re-tune of the pcm to stay in safe a/f and timming parameters. Just a little fyi.
Albert Hernandez.
Albert Hernandez.
#56
How large are the openings on the sl55 t-splitter? Ask, because I can only run around 2 1/4" piping with the c32 splitter. The filter is capable of supporting up to 3.5" piping.
#57
2001 C32 AMG
This thread has taught me a lot on intakes since I just installed a code 3 intake myself I'm curious as to the theory behind it all.
Can someone tell me if its possible to have the IAT's display on your steering display?
I just replaced a intercooler pump that was literally cutting in and out every 5 minutes (5 on and 5 off) that now works great, albeit a big leak initially due to not clamping one of the hoses.. oops
#58
12.2 was the lowest A/F ratio reading we got. LET did a great job on the ECU tune. Even corrected for my higher altitude. The supercharger would disengage, and timing would be cut as you get after IAT too high before any detonation could take place, I think. I don't think it looks riced out, but I guess some people would. Should look better when I'm finished.
On my stage 2 dyno tune my intake temps were significantly higher than the outside temps. By ALOT. Anyway, it's just something to be aware of.
As for appearance, its so subjective. But I like NOT having a huge intake and FMIC pipes all over the place! Lol, i'm sure that has to do with the Subaru's engine bay.
#59
with the code3 intake, your IATs may rise a few degrees. i believe even Brandon said that in his description of the code3 intake product. however, the benefits outweigh the costs of this intake.
#60
2001 C32 AMG
no. it is not possible to have the IAT's display on your steering display. only the engine coolant temperatures (ECT). i purchased an OBDII gauge to monitor and watch my IATs, boost, etc...it is definitely a nice addition
I think on the hot days here though I migth have IAT issues even with the new IC30.
what's the best way to keep them low, even on hot days? I've read heat wrapping but probably the code 3 straight replace heat exchanger will do the trick?
#61
if you want to spend some money:
1) larger heat exchanger
2) split coolant system
3) you've done the CM30
4) heat wrapping could work. no one to my knowledge has shown any results on the C32 though.
5) if you are super serious about cooling, you could use meth-injection and nitrous for cooling....you could also custom coat the intake manifolds with a heat-resistant coating
#62
http://www.youtube.com/watch?v=oNlIRBXC6-o
Video of the dyno runs if anyone is interested. Straps were a little loose that first run. It almost jumped the dyno with an unexpected downshift...
#64
Custom Intake - 327.6WHP/374.3WTQ
Custom Intake - 322.6WHP/364.8WTQ
Stock Intake - 308.9WHP/355.4WTQ
Stock Intake - 305.8WHP/359.3WTQ
I never had the vehicle dyno'ed stock.
#65
C32 AMG
I made a ton of runs on mine from everything between 2nd and 4th gear and it didn't make a measurable difference. Even did a few runs recording from 1st through 4th WOT the entire time. Most seem to run dyno mode and measure from 3rd gear however.
#66
C32 AMG
As for the dyno numbers themselves, here is a comparison of the same car (350Z), same operator, different dynos....just so you can see where your numbers on that dyno match up with others. Point being Dynocom is very generous.
Dynocom results:
Best run: 340.9whp / 315.0 ft-lbs
Mustang Dyno Results:
Best Run: 306whp / 254ft-lbs
Dynojet Results:
Best Run: 311whp / 260ft-lbs
Source:
#67
Good news here is it showed a gain on a dyno. I assume the hood was up, engine fairly cool, and had a large fan blowing on the engine/intake? (I can't watch the video at work, so I'm just assuming here till I see the video)
Dynocom results:
Dynojet Results:
Source:
Dynocom results:
Dynojet Results:
Source:
this site is what makes me think he is actually having major cooling issues and just not knowing it because he isnt monitoring IATs or timing.....asuming that these dynocom dynos actually read that high (i've read elsewhere they are usually within 1% of dynojets)
#68
2003 porsche 996 turbo
josh you know this has been done for yrs on the srt-6 forum. without running tubes to the front of the rad, this setup wont last 5 minutes in the summer. shielding , cones in the engine bay, drilling the backplate all done ad nauseam . full sl55 setup or dual cai or modded oem is the only way to get consistent airflow and hp
#70
and thats why i have the full sl55 setup....and still trying to come up with another way for a needswing style dual intake to fit and work (though likely at the cost of part of my firewall lol)
#71
heres a thought josh.
instead of going thru the rad support how about 90* down along the rad and and point thru the center lower grille? kinda bimmer style
#72
if so, problem there is its proximity to the ground.....high chance of puddle or water splashing up, getting on/into the filter...hydrolock.....death lol. also, i'm sure there will be good exposure in front of or near that grille, but there will also be some heat as it sits right in front of those rotating pulleys....also, if the car is gunned and jerks a little bit, i may be a bit concerned as to how much the intake moves about....and would hope it wouldnt ever come into contact with any of the rotating pulleys or belt lol.
unless you're referring elsehwere.....an extreme way would be to drill holes and cut out a part of the headlight on each side and place some kind of filter on each side there like Blackbenzz has ( IIRC )....but obviously, thats a bit extreme. i'm sure there is a way....hopefully one will be discovered soon
#73
you have the right idea josh. no worry about hydrolock the water would never make the trip up the tubes and thru the 90 bend.
my 32 has tons of room from the front of the engine to the rad. more than enough to get down to the lower grill
#74
hmm. i'll take a look at it later for clearance and such and talk over it and other potential mods for the M112k later over beers with Hooley lol.
#75
i wish GT4AWD had a stock/baseline dyno so we could see what he really is working with and how much total gains (delta) he has seen.
Your car sounds sick!
