need wiring diagram of ecu!!!!!!
2002 SLK 32 AMG
hey guys i just bought o2 simulators for my cel. i have to tap into the wires of the rear o2 senors with the simulators but don't have a diagram of what the wires are coming from the ecu. if anybody know's please can you post it up asap. thanks also i have slk 32 will the diagram be the same a c 32??
2002 SLK 32 AMG
10 speed bicycle
Your car has a total of 4 O2 sensors 2 on each bank, the ones before the cat are upstream, the ones after are downstream. In my previous post I should have been more specific...where do you want to tap in, by the ME-SFI or the O2S?
2002 SLK 32 AMG
thanks again for the help
10 speed bicycle
ME, is the engine control unit...which is located which is locate under the hood on the driver side in the module box. You want connector 4 pin 5 (blue/brown)for the signal out for both sensors, and connector 4 pins 15(blue) for the R/S, and connector 4 pin 16(yellow) for the L/S.
2002 SLK 32 AMG
thanks
10 speed bicycle
There are not really any good pics, but everything is numered on the connectors, also when you pull the connector out of the ME, if you look in the socket it will tell you the connector numbers...pretty straight forward.
Could you please explain in more details how did you mange to turn it off? I have Kleemann headers and cat less sys, I am getting code (Po432) " The efficiency of the left catalytic converter is insufficient "
C32AMG.335 e92 fbo.protomotive996 gt2
no problem,i have a workshop in lebanon and have a star diagnos,but i am now in germany.you have to use the developement data,and than you can do it.the developement data is available in all star diagnos with XENTRY version but it is only in german.when i will be back,i will send you the procedure step by step.it is very easy.
SPONSOR
Location: Houston/ Austin /Toronto / UAE / Minneapolis / Orlando /Cincinnati
Eurocharged Performance ML63 and TT lambo
Yup, he is correct, a developer edition of star does have that functionality.
2002 SLK 32 AMG
could you also send me the directions too. thanks so much
lambda sensor after cat delete
sorry to be late.
1 select developer data
2 control unit adaptation(inside the developer kit dont select the control unit adaptation in the menu where fault memory clear memory,actual value etc.....)
3 read and change coding
4 now there is several options,choose the adress 182(lambda sonde hinten katalysator)choose the option AUS
5 press the button F3 on the laptop
