SC Question
Old Dec 13, 2009 | 05:29 PM
link146's Avatar
'02 325 xi; '02 C32; '90 ZX; '08 CBR 6RR, '86 V45 Magna
SC Question
Happy Sunday fellas:
This morning (pouring rain, about 45-50F) I cold-started my car, drove about two hundreds yards to the end of my street and thought the car was not running as usual. I turned onto the main road and punched it and quickly realized the SC was not humming. I punched it a few times and thought to myself that I am glad i didn't buy a C320. After a half mile I pulled over, turned the car off and then restarted and everything was fine. I drove around, ran errands, shut the car off and on a number of times during the course of the day and the issue never resurfaced.
Has anyone experienced this type of isolated SC failure? I have read stories of intermittent SC engage-disengagement, etc., and know about SC pump failure. Any suggestions? Is there a simple way to troubleshoot the SC, pump, etc.?
BTW - 02 C32 w/ 27k.
Old Dec 13, 2009 | 05:45 PM
320 dreamer's Avatar
2003 porsche 996 turbo
its the pump. the easiest way to diagnose the pump is the next time it shuts down reach inside the door in the pass fenderwell and feel the pump it should be running . if not its toast.
btw the c320 runs much better than a c32 without the s/c!!
jturkel's Avatar
02 C32 AMG
sounds like an i/c pump thing.....though its odd it would kick on so soon after a cold start. you'll usually notice it goes bad when the IATs rise after the car has been on for a bit.
Old Dec 13, 2009 | 05:52 PM
link146's Avatar
Thanks for the feedback. That is exactly what I was thinking. I thought it was strange I had no SC on a cold start then drove .5 mi, stopped, restarted and everything was fine. I was wondering if it may have been a one time phenomenon??
So where is the IC pump located? Are we talking inside the passenger's side wheel well area or inside the engine bay?
Old Dec 13, 2009 | 06:05 PM
my i/c pump was an electrical failure. the windings in the pump were burnt so contacts were being broken. pump would fail hot or cold
pump is under the fenderwell panel on pass side
Old Dec 13, 2009 | 10:05 PM
W203Ramos's Avatar
'03C32 Obsidian Black, '76Toyota Celica GT TRD, '12R350 4matic Arctic White, '06 ML 350 arctic white
passenger wheel well. did mine about 1-2 mos ago. 2hr job. most probably the ic pump like everyone is saying.
Old Dec 13, 2009 | 10:55 PM
loudandheard's Avatar
C32/C55 AMG
I replaced my pump and did a coolant flush, now I get worse gas mileage, lol.
Old Dec 13, 2009 | 11:14 PM
influx's Avatar
'02 C32 AMG, '04 SC430
Read somewhere on here before that it could be the fuse too. Check that first before you go and blow 200 bucks.
Old Dec 13, 2009 | 11:26 PM
link146's Avatar
fuse would cause intermittent failure? anyone know the fuse #?
Old Dec 14, 2009 | 12:09 AM
influx's Avatar
Fuse #4 or 5 in the rear SAM is it I believe. The kickpanel should say when you take it off.
Old Dec 14, 2009 | 01:17 AM
Beaker's Avatar
2001 C32 AMG
This happened with me.. it would usually drop out after the IAT got too high after a few minutes of driving. But everytime no matter what, even if the car had only been off 10 seconds and I turned the car on the s/c would be engaged, if only for a minute.
Replaced my I/C pump and the S/C hasn't skipped a beat.
Old Dec 14, 2009 | 10:41 AM
Zeppelin's Avatar
C32
I guess I am the only one that would disagree with that problem being a intercooler pump. Starting a car up in 40 degree weather and driving it for 200 yards would not be long enough for a IC pump to be a problem. If it were 100 degree temps I don't think the intercooler water would be hot enough to shut down the SC after only 200 yards.
I would think that it might be some intermittent sensor or SC clutch issue if it reset itself after turning the car off then on.
Old Dec 14, 2009 | 02:39 PM
the s/c kicks in at 1300 rpm and the pumps comes on at 2000 rpm and stays on until the engine is shut down. if the ecu senses a problem with the pump, ie a electrical surge it will shut down the s./c as a precaution
just as an example within 1/4 mile the temps can go from 40*C to 80*C with a normal acceleration. s/c heats up very quickly
