Help with my symptoms. Belt slip?
what gaseket did you blow ? is it going to be a b$$$h to replace, if i do mine before you do yours ill let you know i did notice that i had allow coolant i added some but just havent taken it to 120+ yet
03 g35 coupe...........02 c32 Sold
not sure yet...the shop was backed up so they cant look at the car till monday. The gasket or seal is just a guess...my car misfired and blew oil everywhere. I was leaking oil but i couldnt figure out where it was coming from. They should give me a update by monday.
Originally Posted by 320 dreamer
is the 185 the only mod with the tune/ thats way impressive if your bangin 400 ft/lbs with just a tune and 185!!!
2003 porsche 996 turbo
im sure the colder air helps but those are still some great numbers. my c3 modded intakes and custom dyno tune only netted 337 ft/lbs. my search is on for more but i wont change the crank pulley so i may never see north of 350
Dynos measure wheel hp/tq. 337 on a dyno is probably ballpark 400 crank depends on the dyno and some other things. 350 on a dyno would easily be over 400 crank.
![Talking](https://mbworld.org/forums/images/icons/icon10.gif)
![Confused](https://mbworld.org/forums/images/smilies/confused.gif)
I dynoed well over 360wtq - so I am anxious to get this "fix", as suggested...
