Don't do your emissions after you modify your ECU or replace your battery....
my battery or something else within recent days and I forgot I pulled the ECU. Anyhow, I'm guessing some logging is recorded and the inspector said it didn't pass or fail, just not enough data and came up with not enough data on the following:
O2 Sensor
HO2 Sensor
Catalyst
Evaporative System
I'll go back when I have some miles on it. I think I only put like 50 or less on it after the ECU went back in. Glad I did this early and still have a month before the plates are actually due for new tags.
Bob
And actually this causes a big grey-area in the laws. Let's say you're working on a car (something which involves disconnecting power) to get it back on the road and in the meantime the tag expires. You can't renew your tag until you have emissions. And you can't do emissions until you've driven 50-100 miles. But you can't drive until you have a tag.
Happened to a friend of mine. He thought ahead and the tag office wrote him a note stating the predicament he was in. Sure enough, he pulls out of our subdivision to start putting some miles on the car so he can do emissions...blue lights. Literally drove less than 250 feet. Cop let him go with a warning since he had the note, hehe.
If you've got time, keep putting miles on it till you are really close to expiration. Saves the hassle of finding out there are still some monitors that aren't set.
You can google for more info on OBD diagnostics....
try this:
1) idle for 10 mins
2) WOT for at least 5 seconds
3) drive around town for 20 miles
4) drive on the highway at >55mph for 20 miles
the snow comes, I usually drive the SUV or beater.
The following "universal" drive cycle can be used as a guide to assist with re-setting monitors when a vehicle specific drive cycle cannot be located. This generic OBDII drive cycle begins with a cold start (coolant temperature below 122 degrees F and the coolant and air temperature sensors within 11 degrees of one another). This condition can be achieved by allowing the vehicle to "sit" overnight, and then by beginning the drive cycle the next day. Most drive cycles will be difficult to follow exactly under normal driving conditions, so the driver should exercise caution, road safety, and courtesy to others.
1. Start the engine. Idle the engine in drive for two and a half minutes with the A/C and rear defroster on.
2. Turn the A/C and rear defrost off, and accelerate to 55 mph at half throttle.
3. Hold at a steady speed of 55 mph for three minutes.
4. Decelerate (coast down) to 20 mph without braking or depressing the clutch.
5. Accelerate back to 55 to 60 mph at ¾ throttle.
6. Hold at a steady speed of 55 to 60 mph for five minutes.
7. Decelerate (coast down) to a stop without braking.
One of the EPA requirements for using a plug-in OBD II check in lieu of a tailpipe test is to make sure the OBD II system is ready and has run its system monitors. Some vehicles (mostly some import models) have readiness issues when it comes to setting all the OBD II monitors. Consequently, the EPA currently allows up to two readiness flags not to be set prior to testing 1996 to 2000 model year vehicles. For 2001 and newer vehicles, only one readiness flag not set is allowed. Eventually, all readiness flags will have to be set to pass the test.
normal driving you'll need somewhere between 800-900 miles. three tanks of gas at least.
last time when I did this I made 3-4 trips to the smog test ppl because of it.
Bob
It looks like since there are no cel lights on, I'll have to go to DMV and see what options I have as the clock is ticking...
when i did it I just ran it till the empty light comes on and refills.
One of the hoops through which I learned to jump during my illegitimate hot rodding days. ;)
Good luck with yours.
I moved to California and got the car smogged. Silly me, they saw my ram intake AFTER they did the tests and informed me that although my car passed smog test, it failed visual inspection. Gee, thanks for telling me that afterward so I could wait around for a half hour and waste my money.
I took it out and put my stock airbox in. Battery died. Didn't think anything of it, so I jumped it and a day or two later took it to the same place for re-test and it failed again. WTF. I was livid... I really hate this state.
Took it for a 3rd time after driving it some more (and doing the standard drive procedure) and it passed.
But this brings to mind a question... will the ECU tunes offered by eurocharged make the car fail emissions (this question is for my SRT6)? Not trying to hijack the thread, but since we're on the topic of ECU's and emissions...
test. I've had other tunes on other Mercedes and no problems, even tunes on
my older GTI with no issues. Stuff just happens I suppose at a time you least expect it.
