True dual exhaust for c55...whose done em?
I'm planning on reworking my exhaust system for my car to a true dual set up with an x-pipe right after the downpipes. However, my only speed bump I see in making the true dual exhaust is the rear sway bar. It has that bump on the left side that gives clearance to the single pipe, but not to the other side. Did anyone, who has done this, just route the pipe a little lower on that side compared to the stock route for the piping?
Any input on the exhaust path, and especially if you think an x-pipe would help create more gains and reduce drone, would be beneficial.
Thanks again guys.
The only thing I'd like to do is maybe install the x-pipe then to reduce drone...
or maybe put a glass-pack style resonator to reduce a little bit of drone?
-stock exhaust manifolds
-stock primary cats
-stock secondary cats
Everything past the 2nd cats is free flowing (both resonator & mufflers) nothing else needs to be done including changing piping. If you tackle those three issues (which it looks like you have already started w/ 2nd cat & res delete) then you will be done with the exhaust system.
With the kleemann headers and true dual exhaust I gained a little south of 20rwhp. I am sure most of the power was from the headers fwiw. The right side just needs some good work from a shop, but it can be done.
Thanks again guys.
http://www.youtube.com/watch?v=1da_AKDISho
I recon the GMC is ready for your rx6 1/2!! I still got your engine in the back of my bed rolling around LOL.
With your set up is drone reduced and the exhaust smoother sounded (rather than like a tractor) because of the mixing of the exhaust pulses?
I actually think it sounds a little smoother than just having the secondaries and resonator removed. I havnt been able to get on it WOT with the windows down yet due to it being rainy in ATL the past couple days so I dont have a good reference to my old setup.
